351m problem
Old Jan 22, 2010 | 10:59 AM
BigJake34452's Avatar
BigJake34452
351m problem
hey guys, i have a 76 f-250 with a 351M, edelbrock performer 400 manifold, edelbrock 600 carb. mild cam. the truck seems to run great but only in the 0-175 degree temp range. once i get closer to 180-200 the truck runs very badly, very rough idle and it smokes but it doesnt smell like oil or antifreeze but it seems to have a blueish look to it. when i shut it off when its running like that it will take a while to start back up. also the truck dang near wont run unless its on very level ground, even parking in a driveway that is slightly angled it wont start until i let roll back to level ground, im guessing that is carb though, thanks for any help.
Old Jan 22, 2010 | 11:25 AM
Furyus1's Avatar
Furyus1
Just a guess, but it sounds to me like the carb is getting too hot and is boiling the fuel out... Do you have an insulating spacer between the manifold and the carb?
Old Jan 22, 2010 | 03:40 PM
BigJake34452
i take it you mean the rubber spacer? if so then yes that is there.
Old Jan 22, 2010 | 05:54 PM
maskedman's Avatar
maskedman
Usually a fibre or phenolic spacer gasketed on both sides.Helps to insulate the carb from the manifold heat.Also helps to build air velocity in the intake manifold.
Old Jan 22, 2010 | 08:18 PM
BigJake34452
ill look tomorrow but im almost positive it has it, i took that carb off once and remember a spacer like that.
Old Jan 22, 2010 | 09:07 PM
ctubutis's Avatar
ctubutis
I have this one, made of wood, for my 4V:
Edelbrock 8725 - Edelbrock Carburetor Spacers - Overview - SummitRacing.com
hail destroyer
Apr 22, 2016 10:21 AM
BossFan
Aug 17, 2014 07:21 PM
Az58Cameo
Dec 3, 2013 10:43 PM
FatherDonald74
Sep 11, 2013 11:31 PM
soundman502
27
Mar 9, 2007 03:40 AM
