replacing points with electronic ignition
Old Nov 8, 1999 | 11:44 PM
rick's Avatar
rick
HI all,
Thanks for the previous help...here we go again. A friend has a '72 with points. He wants to replace with an electronic ignition. Does he need to do anything besides just buy the new distributor? What problems (if any) are associated with this. Any help on this would be appreciated as I will be doing the same on my '78 in the upcoming months!
Thanks,
Rick
Old Nov 9, 1999 | 02:25 AM
BigBrownTruck's Avatar
BigBrownTruck
I converted my 69 390 with pointed ignition with a Crane digital electronic ignition conversion. It uses the distributor you already have. I had mine cleaned,curved,and it has an optical (like mallory unilite) pickup assembly installed where the points were. I had the shop install the pickup and set up the distributor, the rest of the wiring was very simple. I believe my total cost was around $160. It also utilizes the coil you already have. So far it has worked great.
Old Nov 9, 1999 | 03:30 PM
sparky's Avatar
sparky
Check out this site. Should have the info you are looking for.
<a href="http://www.wrljet.com/engines/duraspark.html">http://www.wrljet.com/engines/duraspark.html</a>
Good luck.
Old Nov 9, 1999 | 06:05 PM
john h's Avatar
john h
Just finished replacing my points with the `Pertronix` point module. (85.00).... 72 f-250 390 4bl
I had previously Up Graded to the Large Later type cap and rotor ( handles the 8.5 mm wire )I got the large cap adapter at the junk yard....
Everything just slipped in!!!! and away you go.
__JOHN__ 72 F-250
Old Nov 9, 1999 | 06:17 PM
john h's Avatar
john h
tyrantsparky
19
Jan 22, 2014 06:40 AM
wood0691
44
Apr 25, 2013 08:02 PM
fbama73
Aug 18, 2008 04:21 PM
1969RANGER360
13
Mar 4, 2004 02:39 PM
