Electronic Ignition
I haver a buddy who has finally come out of the darkness and into the light- he sold his 1 ton bowtie, and bought a 74 F350 with a 360/390. It has points, and he'd like to go electronic.
The Pertronix system looks nice, but he'd feel better using factory parts, so that he can get replacements at the local parts house.
So we need a new distributor and module. How do we decide what module we need? and exactly how do we wire it in.
Much thanks in advance for any help.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
It wasn't too bad finding replacement parts for the DUI I had in my other truck, but for a stock engine that system is a bit pricey. You can get everything for a DS I or DSII conversion from any parts store for under $200 as long as the core charge on the distributor is reasonable. Get a distributor for a 75 with a 360, cap, rotor, and cap adaptor for a 78 or so with a 400 so you get the big cap, and get a module and coil for a 75 if you want DS I or a 78 if you want a DSII. You'll need another +12v key on power source under the hood for the module, but that's just one wire and not hard to run.
As far as over-the-counter Durasparks are concerned, beware of their worn out upper bushing-they only have one. We utilize a full length oil impreganted bronze bushing in our Durasparks. This improves timing accuracy and it will be more durable for you. Over-the-counter Durasparks also can have worn out advance mechanisms. And of course, our units are custom tuned on a distributor machine, whether you get our Duraspark or DUI.
Ford Duraspark
FTE Sponsor
