Modular V10 (6.8l)
PCM swap
Old Jan 21, 2010 | 02:09 PM
JJz400's Avatar
JJz400
PCM swap
My PCM's memory went bad and would not throw a code for my bad coil.
Dealer said the memory was bad and would run but not remember things or learn. Mine is a 99 v10 with auto, I found a 99 v10 Manual trany pcm. Dos anyone know if it will run my truck or do I have to have it programed for the auto trany.
Old Jan 21, 2010 | 03:05 PM
green250's Avatar
green250
Not sure it will work.I just swapped out pcm's ad learned the hard way about them.The manual wont control the tranny and im not sure you can program that in.Even if you can it will cost you a programmer.You also want to make sure the pcm is the same... 4x4 or 2 wheel as yours.If you get a 2wheel pcm and yous is a 4x4 you will throw tranny codes....o/d button will blink.that can be programmed though.Talk to mike at 5 star tuning and he should be able to help you with your pcm as he did me.just try and make sure you get a pcm with all the options yours had.Sorry i wasnt more help!
Old Jan 21, 2010 | 03:12 PM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
The manual tranny PCM would have to be reflashed to work in auto.
I have a spare 99 auto PCM in the shop.. Was your PCM code AEO1 or AEO2?
oachs83
1997 - 2003 F150
Jun 13, 2017 09:53 AM
Bhildreth99
Large Truck
Sep 17, 2016 01:47 PM
FuzzFace2
Jun 20, 2016 10:13 AM
rwdfan
WTB - Ford Trucks & other vehicles
Feb 2, 2012 02:36 PM
wildstang
Sep 1, 2009 09:27 PM
