seen these wheels before anyone?
#31
There were TWO versions of those rims available as an option for this generation truck.
12-hole aluminum WITHOUT rivets and 10-hole aluminum WITH rivets.
I've got the 10-hole versions on my 92.
Finally found ONE of them in the junkyard to complete the set (it only had three when I bought it and was running spare steel painted "Hurricaine" wheel as the fourth).
#33
#34
#37
#38
#39
Those LMC wheels are aftermarket. They are not the same as the OEM wheels. The OE center caps will not fit them either. Also, those aftermarket aluminum ones generally require polishing to keep them looking good. I had a set of what they are calling modular and will never do that again.
and the only people that would be able to tell the difference
would be people who have studied the rims
polishing the rims every so often is better than getting steel
rims and have them rust away had a white spoke 16" rim rust around the lug nuts and come off the truck while driving.
#40
fasthauler
08-13-2015 11:51 AM
1956f350
05-18-2013 07:26 PM
Wayne Waldrep
34
10-26-2012 01:46 PM
Mayerstom
06-24-2009 06:20 AM
