1956 F350 wheel ID help
I need some help with identification of the wheels in the following pics:
This one is on a 56 F350 cab-chassis dually. Not much pic of wheel, but the tire size can be seen as 7.00-17. Could this be an original wheel? The 17" wheel size tells me it's not a 1 pc drop center. Any definition in the pic to tell if it's 2-piece side ring or "widowmaker" design? If not, if it's stock original, does that define the wheel type?
The next pic are of spare wheel/tires bought for the same F350 cab-chassis. Tire size not visible ... but hopefully pic of wheel should provide definition of wheel type??
Thanks, Jim
Thanks, Jim
The spares (2nd pic) looked like side lock ring to me but I couldn't find the split in the ring to confirm (probably located where pic is cut off - my luck). If these are side lock ring 17's, they should not be dangerous like "widowmakers", yes/no??
If I try for more pics or make the trip myself, any tips on what to look for to determine which style they are.
I know the front & back appearance of the tubeless 17.5's #73230 (6 hole) & #79120 (3 hole) when I see them, and there is also a 2pc side lock ring 16" - 6 on 7.25" wheel that is ok to use (used on 60's Ford, IH & Dodge), but I know nothing about any 17" - 6 on 7.25" wheels.
Any further education would be appreciated.
Thanks Ray & Stu for your help on this request.
Jim
jmadsen
17
02-09-2014 10:07 PM
62Jimi
09-07-2009 07:12 AM
fordf350camper
03-31-2009 09:07 AM
