78 wont start
Old Jan 23, 2010 | 05:58 PM
bmuhlbach's Avatar
bmuhlbach
somthing else to throw out is it truck warm when it is hard to start if so you could have the distrutor to advanced that it would turn over slow.
Old Jan 24, 2010 | 01:08 AM
clhart426's Avatar
clhart426
not really, i mean, its 20s-30s here and if it doesnt fire up the first crank, the cranking is sllllloooooowwweed down a lot
Old Jan 24, 2010 | 12:22 PM
bmuhlbach's Avatar
bmuhlbach
A Ford starter will slow down when its about to go out in my experience.Also i had a 400 M that the distributor vacuum advance was stuck advanced and it turned really slow also.
Old Jan 24, 2010 | 01:41 PM
starmilt's Avatar
starmilt
It is easy to jump the selonoid it self and see if the problem is in the cables or batteries or in the selonoid. Do not jump from the battery as that eleminates the hot cable and the selonoid. Jump across the selonoid itself big post to big post if it spins fast you have eliminated the cables and starter if it spins slow you either have a battery or a cable or possibly starter problem. It is uasually a cable problem also if you have a cable problem your battery may have not been charging properly and could be low.
Old Jan 24, 2010 | 01:52 PM
fmc400's Avatar
fmc400
MSEE
Not only is this extremely dangerous, it's incorrect.
gearhed1971's Avatar
gearhed1971
If the engine is up operating temp,hot timing will be more of a nuisance.The starter will act sluggish.
Old Jan 24, 2010 | 02:55 PM
clhart426's Avatar
clhart426
im pretty sure its the starter now. as my uncle tried that trick with the screwdriver, it was working fine. as he turned the key i tapped on the starter and what do you kno-fired right up. so, starter is what im assuming it needs
Old Jan 24, 2010 | 03:38 PM
bleedblue79's Avatar
bleedblue79
wont start all the time but can jump start
sounds like new batt has to low of cranking amps or bad new batt
Old Jan 27, 2010 | 05:02 AM
firman's Avatar
firman
didnt read that u checked your ground off battery, my 79 started doing that cleaned my connections, still would click hooked a new ground up and it fired rite up.
Old Jan 27, 2010 | 07:06 PM
gearhed1971
I agree w/ firman,have had that happen on more than one occasion.
fordatic
Sep 23, 2016 01:28 PM
zdumpor
1978 - 1996 Big Bronco
Jul 10, 2016 03:49 PM
Jo Diesel
Large Truck
Mar 30, 2016 04:50 AM
PDX_F250_78
15
Oct 16, 2015 03:02 PM
78BigBlock09
Mar 30, 2010 02:48 PM
