How do I figure out where my fuel problem is?
Old Jan 20, 2010 | 10:54 PM
F-250 Ranger's Avatar
F-250 Ranger
About the truck: 1974 F-250, 390, 2bbl.
The truck has been sitting for 5 years. It ran well prior to that. I did some basic stuff to it and was able to get it to run for about 10 seconds at a time by pouring gas into the carb, so I know my problem is fuel rather than spark. I checked the fuel line and filter and they both were bone dry. How can I tell if the problem is the fuel pump or something with the gas tank? Getting to the fuel pump will be hard because of the factory air compressor. I am a complete novice with cars so I'm not sure whet my next move is. I'm rebuilding the carb, but don't know what to do when I put it back on. Any advice is appreciated. BTW, here's some pictures of Flo.
Old Jan 21, 2010 | 07:44 AM
fmc400's Avatar
fmc400
MSEE
The fuel pump is easy to get to; it's pretty far away from the AC compressor. Get to it from underneath. If it has been sitting, most likely there's a breach in one of the rubber fuel hoses along the fuel line. There's a metal line from the tank to the pump; a rubber hose connects one end to the pump, another one connects the other end to the tank, and sometimes there is a short length of hose in the middle. The last two are often overlooked, and often cracked. If air gets in your fuel line, the pump can't siphon. The problem could also be the fuel pump itself. Check the oil to see if it smells like gasoline. That truck should clean up nice. Welcome to FTE!
Old Jan 21, 2010 | 07:56 AM
magusjinx's Avatar
magusjinx
First make sure there is fuel in the tank ... You would be surprised how many forget that ...
Old Jan 21, 2010 | 09:02 AM
F-250 Ranger
I know I can reach the fuel pump from underneath. The problem is I underestimated the size of the truck and only bought a 2 ton jack. I don't know if I can get it high enough to get to the fuel pump. I think I'm going to end up getting a 6 ton jack. I didn't realize how high the truck is.
Old Jan 21, 2010 | 05:17 PM
LxMan1's Avatar
LxMan1
It sits high enough that you shouldn't need a jack, just crawl up under it.
Make sure the oil doesn't smell like gas. Often the pump diaphragm busts and pumps fuel into the engine as well. Another thing to check is the tank to frame rubber hose. they can dry rot and allow air to be sucked into the line. I would definitely start with the pump after sitting 5 yrs.
Benchwrench
May 15, 2025 10:14 AM
F-250 Ranger
Jan 21, 2010 02:31 AM
F-250 Ranger
Jan 20, 2010 11:07 PM
jwstrand
48
Aug 4, 2009 06:54 PM
luvmytruck460
16
Apr 7, 2007 09:10 PM
