tach
Old Jan 20, 2010 | 09:27 PM
rodneywar's Avatar
rodneywar
tach
My tach hasn't worked since i got the truck. I am curious as to how to fix it and I am familiar with how the psd tach works. is the systems similar? Also what to i need to check?
Old Jan 20, 2010 | 09:48 PM
Dave Sponaugle's Avatar
Dave Sponaugle
PSD tach's work of the CPS.
IDI tach's work off the sensor on the IP drive gear, and that is probably where your problem is.
Look for the insulation to be pulled back exposing bare wires where they go into the sensor.
Old Jan 20, 2010 | 09:55 PM
rodneywar's Avatar
rodneywar
Alright thanks is there a fuse that protects that circuit?
Old Jan 20, 2010 | 09:58 PM
Dave Sponaugle
Insturment panel fuse.
What transmission do you have?
Old Jan 20, 2010 | 10:05 PM
rodneywar's Avatar
rodneywar
E4od tranny
Old Jan 20, 2010 | 10:14 PM
Dave Sponaugle
So your transmission is not working right either?
Old Jan 20, 2010 | 10:22 PM
rodneywar's Avatar
rodneywar
it shifts funny around 35 mph other than that it is fine compared to my psd e4od
Old Jan 20, 2010 | 11:10 PM
wreckinball's Avatar
wreckinball
so the tach just plugs into the sensor in the IP housing? thats it? Can i get a tach from a junker and just plug in and have a working tach?
Old Jan 21, 2010 | 07:51 PM
Dave Sponaugle
In your 150 cab, I know the wiring is not there.
Tach sending unit plugs into the harness, and on diesels the harness has the wiring in it.
Clusters that did not have a tach, do not have the printed circuits on them for the tach.
If you get the cluster with a tach, then run wires from the sensor to the cluster plug, you should be able to have a tach.
Old Jan 21, 2010 | 11:02 PM
wreckinball
sorry if i hijacked a bit, i was just shocked to know it may have the potential to be very easy. I will look more into that one offline! Thanks
Old Apr 4, 2010 | 02:38 PM
NDFordman's Avatar
NDFordman
Aftermarket tach?
Is there any way to hook up an aftermarket tach to the sensor on a 6.9?
Old Apr 4, 2010 | 06:58 PM
kenpobuck's Avatar
kenpobuck
I think ours use what is called a 'hall effect' tach so a regular gasser tach will not work.
bcamill
May 31, 2015 07:59 PM
quesey
1978 - 1996 Big Bronco
Dec 26, 2013 06:10 PM
Israelx7
Nov 29, 2013 08:51 AM
Old Hickory
Feb 26, 2011 08:39 AM
scottscott
Apr 22, 2010 04:08 PM
