ok guys tomorrow im going to have a printer avalible to be so id like to print out all the info i need before the NEST meeting at Petey's this weekend
List of things im doing to my truck:
fuel bowl remove and rebuild
install a new back pressure tube
remove and re install hpop
all new o rings on hpop and the u"non serviceable" plug install
05-07 grill install
clay's ocr install
No problem. BTW a pair of needle nose works great to remove the lines from the HPOP. And, be sure to have a fuel line sleeve kit for the fuel bowl lines. You should be able to reuse the reservoir and HPOP gaskets. Treat the IPR like an egg...
