singel shot or split shot thats the ?
Old Jan 20, 2010 | 06:47 PM
charlie92/7.3l's Avatar
charlie92/7.3l
Red face singel shot or split shot thats the ?
so i have a set of aa injecters from a 96 and a set of 99 split shot i am going to put a chip in my truck mostly for fuel eco not looking for a lot of power maby45 to75 hp my 95 f250 psd gets 19 to 20 mpg my 99 f250 psd gets 16 to 18 the only diferance is 95 2wheel 99 4wheel same gear i would like to get more mpg .
Old Jan 20, 2010 | 06:51 PM
Izzy351's Avatar
Izzy351
Singles give you better mileage and power, but AAs are small in stock form. You can have them mod'ed for more fueling.
What year truck are you putting these in?
Old Jan 20, 2010 | 06:52 PM
HD Rider's Avatar
HD Rider
A lot of poeple here have said that you pick up a couple mpg's with the single shots so that is the route I plan to go when the time comes.
My goals are the same as yours. I don't need to be the first one to the top of a grade. I want to be the last one that needs to stop for fuel.
Old Jan 20, 2010 | 06:54 PM
big poppa's Avatar
big poppa
Not sure if any of those senarios is Joe, lol, he likes to do both.. I'm shootin for hybrids, a little more money but can be tuned for your specific needs, and then be re-tuned for different power levels, nice feature..
Old Jan 20, 2010 | 06:58 PM
PaysonPSD's Avatar
PaysonPSD
Here's some info on the injectors you have:
A and AA injectors came in the '94-'97 non-california trucks. They are all 90cc injectors and are single shots.
AB injectors came in the '97 cali, and all early '99 trucks. They are split shot injectors meaning they fire a small pilot shot before the main shot. These injectors flow 130-135cc of fuel.
AD injectors are also split shot but flow 135-140cc of fuel due to a slightly longer plunger stroke. These are found in all late '99-'03 Powerstrokes and T444Es.
The 99s you have may be AB or AD.
Single shots are supposed to return better MPG. I sure hope so because I am going to buy a set.
Hopefully those who have run both will chime in.
Old Jan 20, 2010 | 07:16 PM
charlie92/7.3l
so if i were to just convert the split shot to singel shot i should get more mpg and a small bost in power with the programer. the aa were in a 95 i bought that is in good shap im puting it in my 99 so i will have a moter i plan to rebuild better than new
Old Jan 20, 2010 | 07:20 PM
Izzy351's Avatar
Izzy351
The AAs WILL NOT have more power than the splits in your 99 now, unless you get them mod'ed. They probably will do better MPG-wise, but you WILL require tuning to run them in the 99, since it's setup to run splits. You're going from 130-140cc injectors to 90cc injectors. Get them mod'ed. My 235cc hybrids started out as AAs. I can get 22+mpg out of 'em -or- over 400hp. Not both.
Old Jan 20, 2010 | 07:29 PM
7.3 Rocket's Avatar
7.3 Rocket
Whatever you end up deciding on I'd recommend you take a look at Riffraff Diesel for your purchase.
I've spent literally thousands of dollars with them and have had nothing but a pleasant experience every time I've bought something.
You'd be extremely hard pressed to beat their level of customer service.
Old Jan 20, 2010 | 07:40 PM
charlie92/7.3l
ok i meant that i could mod the 99s to singel shot hybrids wile the moter is out i plan to put in some gages i would like to ceramic coat all the exhaust and change some of the intake
Old Jan 20, 2010 | 08:08 PM
duck fan's Avatar
duck fan
Because racetruck
Man, it sounds to me like you need to hook up with Clay @Riffraff Diesel. He can answer all your injector questions plus get you a great price. Also, I got all my ceramic-coated stuff from him. He has great prices and the guys around here will tell you that you won't beat his service. http://www.riffraffdiesel.com
Old Jan 20, 2010 | 08:14 PM
Izzy351's Avatar
Izzy351
Have Ryan Casserly mod your sticks. How much power are you looking for?
Old Jan 20, 2010 | 09:13 PM
charlie92/7.3l
not much 60 to 75 hp all the time the ceramic i will do my self i have a large oven we are finishing soon dont trust tomany people with mods. been screwed tomany times leared how so i would make sure it is done right ill rebuild my injecters have done aa injecters just not split shots befor dont think there much different
Old Jan 20, 2010 | 11:45 PM
duck fan's Avatar
duck fan
Because racetruck
I have heard some stories about modding your own injectors. They really need to be flow tested to do the job right. Casserly injectors, plain and simple. Its not something you want to cheap out on.
Old Jan 21, 2010 | 07:58 PM
megawatt00's Avatar
megawatt00
I have Casserly Stage 1 SS in my truck with a 38R Turbo and it moves. The SS have a bit of a lope/rougher/ louder idle to them though. I dont mind it sounds like horsepower to me
Old Jan 21, 2010 | 08:24 PM
Izzy351's Avatar
Izzy351
Stage 2s will get you 60-75 RWHP. Stock, look for 310-325. With stage 1s, look for about 350-375. Stage 2s should get you 375-400.
