Sponsored by: Real Truck
4Wd...
Old Jan 20, 2010 | 04:52 PM
AGORA's Avatar
AGORA
4Wd...
Hi...whats the difference between the floor shifter or dash switch on 4Wd option? which one is better and why? thanks in advance....
Old Jan 20, 2010 | 05:58 PM
cfile's Avatar
cfile
Others will be along to explain it better, but I'll take a stab at it.
With the floor shifter, you have direct linkage to engage the transfer case. With the switch, you are relying on actuators to complete the process.
Personally, I'd rather have the floor shifter, even though mine has the switch. If I was to custom order a truck, it would have the shifter. I just like knowing I'm in direct contact.
Old Jan 20, 2010 | 07:38 PM
AGORA's Avatar
AGORA
Thanks for the reply..... with either option do i need to get out and lock the hubs?
Old Jan 20, 2010 | 07:40 PM
Monsta's Avatar
Monsta
Sit. Stay.
"Better" is subjective.
Switch on dash (ESOF) also means automatic (sometimes) locking hubs. Advantage: [size](when they work)[/size] You don't have to get out and turn the hubs. Disadvantage: Things break...just search "hubs not locking" or "Defrost only".
Lever on the floor requires that you exit the vehicle to lock the hubs unless you lock them prior to setting out on your trip. Not a big although a "disadvantage" to most, unless you get and get stuck in horrible weather and really don't want to get out in it to lock your hubs.
Advantage: You know the transfer case is locked. No guess work.
Old Jan 20, 2010 | 07:41 PM
senix's Avatar
senix
cfile is on track.
The manual shifter on the floor is the old fashioned way to engage your transfer case. Direct linkage. That means so are your front hubs. Gotta get out and turn them to engage.
The other system, known as shift on the fly, is a solinold activation system. Turning the switch tells a solinold in the transfer case to activate and put power out the front of the transfer to the front axle.
This switch also sends a signal in the engine compartment to another solinold which then sends a vacumn to the front hubs and turns them to lock in the front end.
hope that helps.
the old fashioned why is gonna be more reliable but the other is pretty good.
Old Jan 20, 2010 | 08:07 PM
AGORA's Avatar
AGORA
Thanks guys, so..floor shifter is more reliable but dash switch is more practicle.I am guessing that repair cost would be higher with dash switch.Thanks again for the replays..
Old Jan 20, 2010 | 08:10 PM
racinghoss's Avatar
racinghoss
The manual system is cheaper and a little easier to repair, even though it requires ALOT less repairing. It also leaves no doubt that you are in 4wd.
I am a beleiver in the "old fashioned" lever system. The electronic system is way too prone to failure. There are usually at least a couple threads on the first page about the electronic system. The hubs for it also need a couple of revolutions to engage, unless you get out and manually engage them.
GamerGirlAlice
Jul 20, 2013 11:06 AM
ufvj217
Dec 20, 2010 03:12 PM
dougandrochelle
Jan 8, 2004 06:53 PM
FortyFords
Oct 16, 2002 03:23 PM
cubster
1983 - 2012 Ranger & B-Series
Dec 7, 2001 12:34 PM
