Center Bearing
Old Jan 20, 2010 | 07:05 AM
OTTOMATIC's Avatar
OTTOMATIC
Center Bearing
Does it need to be pressed off & on ?? I need ito replace it. The reason I ask there are NO shops with in 60 mi. I can't even get brake rotors turned.
Old Jan 20, 2010 | 07:50 AM
riverrat41's Avatar
riverrat41
Not exactly sure what you are talking about?Carrier bearring on the drive shaft??
Old Jan 20, 2010 | 07:54 AM
mxracer3276's Avatar
mxracer3276
Yes it does need to be pressed on and off. Had to get mine done a couple months ago.
Edit: Here is a thread i started on my carrier bearing, hope this helps a little.
https://www.ford-trucks.com/forums/8...riveshaft.html
Old Jan 20, 2010 | 08:06 AM
03_PSD's Avatar
03_PSD
Matt, no linky?
I think my carrier barring is going south too.
Old Jan 20, 2010 | 08:08 AM
mxracer3276
There we go, forgot to paste it in there, thanks for the heads up Glenn
Old Jan 20, 2010 | 04:33 PM
OTTOMATIC's Avatar
OTTOMATIC
Thanks. Looks like I'll have to wait till I get back to TN
Old Jan 20, 2010 | 08:33 PM
mueckster's Avatar
mueckster
You can get it off by removing the rubber mount and grinding through the races until they are thin enough to split with a chisel (cutting torch works well if you are proficient with one). Knock of the old bearing and drive on the new one with a hammer and punch or the appropriate size pipe. I have done many a one this way over the years.
Old Jan 20, 2010 | 09:33 PM
rbaker6336's Avatar
rbaker6336
I have changed a bunch in 40 years (smaller and a bunch bigger) and yet to use a press
