Squeaking from Driveshaft...
Old Jan 4, 2009 | 01:54 PM
mxracer3276's Avatar
mxracer3276
In my 2003 ford 350, DRW, 2WD, there is a bad squeaking coming from the middle of the driveshaft. The is a rubber cover right after what i was told is called a tower bearing..? That is right where the squeaking is come from. I was told to change this bearing and see if it solves the problem. Does this sound correct to anyone? Is there such a bearing? Hard to change? Prices?
Old Jan 4, 2009 | 01:58 PM
gunnertom's Avatar
gunnertom
That would be the carrier bearing
Old Jan 4, 2009 | 02:00 PM
mxracer3276
Yeah i just found that out after searching it a little better.
Old Jan 4, 2009 | 02:01 PM
gunnertom's Avatar
gunnertom
the bearing is not that pricey but you will need to press it off an back on.
Old Jan 4, 2009 | 02:02 PM
King0581's Avatar
King0581
Carrier bearing is what I would call it also. I'd say that's definitely the problem. Either that or a U-joint gone.
Old Jan 4, 2009 | 02:09 PM
mxracer3276
Yeah i lifted the rear of the truck up and put it in drive and it sounds like it is definitely coming from the carrier bearing. Any ideas on how long this will last for, it's been doing it for about a month now and i've actually taking a long trip. If i let it go to long will the bearing lock up on me or anything?
Old Jan 4, 2009 | 02:15 PM
King0581's Avatar
King0581
If it's already been making the sound for a month I would get it fixed quick!
Old Jan 4, 2009 | 02:18 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Carrier bearings are a funny critter. It my last a year like that, or go out tomorrow. I would look for a driveline shop in your area and have them replace it. If you can drop the entire driveshaft, from tranny (or transfer case)to rear axle, have them change the bearing and balance it. You might consider replacing the u-joints at this time too. I personally like the greasable ones, but to each their own. I prefer to grease them at each oil change.
Old Jan 4, 2009 | 02:25 PM
mxracer3276
Ah man, it's one thing after another with this truck!
Old Jan 4, 2009 | 02:30 PM
gunnertom's Avatar
gunnertom
It's not that bad,it could have been a rear !
Old Jan 4, 2009 | 02:31 PM
King0581's Avatar
King0581
Its funny you mention the greaseable joints, John. My local parts place has a lifetime replacement balljoint that is not greaseable and more expensive but the one year warrenty balljoints are greaseable. I know we're talking about U-joints here but I thought I would throw that out there cause I thought it was funny.
Old Jan 4, 2009 | 02:37 PM
CampSpringsJohn
Yeah, I know what you're saying there. A few years ago, I had replaced the carrier bearing and u-joints on my work truck at the time and while at the shop the guy says "I assume you want the non-greasable u-joints." I said no, I want the greasable ones. He looked at me and said that the non-greasable ones have a better warranty. I said, "I don't care. I just like the idea of greasing them. That way I know they have grease in them." In my line of work, I have seen many bearing failures due to lack of lubrication, not one from having too much!
Old Jan 5, 2009 | 02:45 PM
mxracer3276
Hey guys, just wanted to say thanks for the help. I took the driveshaft off and got the part then took it to my buddies machine shop and did it there. Sounds great no squeaking at all. Thanks again everyone.
Old Jan 5, 2009 | 05:21 PM
King0581's Avatar
King0581
Glad you got it going.
Mattman81
Jan 17, 2017 12:38 AM
possom813
Sep 8, 2016 11:10 AM
Kemicalburns
Aug 8, 2016 08:30 PM
Rob04
Nov 2, 2006 01:46 PM
randallc
Electrical Systems/Wiring
Jan 9, 2006 04:01 PM
