Am I on the 7.3 Thread
Old Jan 20, 2010 | 05:06 AM
corn-dog's Avatar
corn-dog
Hey All,
New to site. Posted some stuff last night and was referred to the 7.3 thread....
Did I find it ?
Going to take an '03 F350 with the 7.3l to my mechanic today and hopefully grab my first Diesel today!
corn-dog
Old Jan 20, 2010 | 06:07 AM
Smokin''s Avatar
Smokin'
Smokin
I believe you are in the right spot.
Welcome to FTE.
Check out the list below. You can give this to your mechanic as a guide for common problems and things to look for.
Originally Posted by Tenn01PSD350
Ok all. This is my stab at streamlining the what to look for when looking at buying a 99-03 PSD truck. I will take the first stab at it and would like all of you to throw in what you think is specific to these vehicles. Some of it may be vehicle nonspecific but useful nonetheless.
My intent is to compile ideas (aka brainstorming) then cut and paste into one item. Can we do this Scott, Dan? Don't want a lengthy thread and I don't feel like doing a forever search. I know how it is searching for things here sometimes.
I will break it down into categories:
1. Visual: Body and rust are obvious items, nonspecific.
A. Engine
1) Check for any obvious fluid leaks, especially the engine valley, tranny weep hole area, and around the turbo and pedestal.
2) Check coolant with strips and find out the record of any changes or water pump replacement based on mileage.
3) If possible, do compression check, and Cylinder contribution test.
4) Inspect turbo inlet side vanes, should be straight and not dusted or jagged. Try to move the shaft in and out and up and down. Any real noticeable movement by hand is bad. Open and inspect air cleaner assembly for an idea of how it was maintained.
5) If possible, have fuel pressure tested at engine to check pump.
6) Check all intake /intercooler boots for residue or leaks and correct before trying to determine engine condition.
7) Look at oil pan for notorious rusting, make sure not beyond repaint type repair.
8) Know whether you're getting forged or PMRs. 99-mid 01 = forged, anything later is possible or for sure PMR. Not an issue until you exceed 400HP.
B. Transmission, driveline and 4x4 system.
1) Look for any obvious leaks.
2) With the system in 2wd, grasp and rotate both front drive axles and ensure they rotate freely. Go to the hubs, ESOF and manual should rotate from lock/auto to free with no problems.
3) Grab rear driveshaft and push up and down along it's length checking for worn u-joints or bearings.
4) Check front and rear differential levels. (An indicator of maintenance) Level should be at or w/in 1/2 inch of check plug.
2. Test drive. If you have never owned a 7.3 PSD, try to get a 7.3 owner to test drive it. I did this with a friend who bought his new. Invaluable evalation because you have no idea. A stock PSD may feel like a slug to the gasser uninitiated but it can pull a house off of it's foundation. So here we go.
A. Drive more than one PSD truck that you are considering. Whether Auto or Stick, it will give you an idea of the overall condition of the one you want to buy. Cost = 0. Learning curve = super high. Dealers have a ready supply.
B. Startup. Turn key and watch wait to start light. The colder it is the longer it will take but should take no longer than 15-20 seconds on even cold days. Start engine. Should crank readily and turn the tach while cranking (although mine does not). Should start within 2-5 seconds of cranking. The colder it is the longer it will take but if longer than 5 seconds there may be a problem. Even in colder weather. If it does not not start easily on the second try, suspect problems, possibly in the glow plugs or GP relays. If it does not crank readily, or seems to drag, suspect batteries first, starter next, then cables.
C. Driving. Check all operational items. Don't be rushed. This is a major investment and you want to get it right. Even small items like the cruise will set you back.
1) Auto tranny: will feel like it takes the throttle to get moving with a stocker. The higher the mileage, the worse this will be. The shift should be smooth but slippy with a stocker. Long to engage. Convertor lockup will be almost imperceptable, but there. Will lock up at about 45 to 60m depending on throttle in OD. Should drop out of OD with input to brake or reduction of speed.
2) Standard: give input
3) Ride: if it is bouncing down the road, you can look to having some problems to take care of. These can be tire balance. Tires, or some unexplained seemingly incurable symptom that you may have to live with which is unacceptable and not common, but does happen. Some say it is an out of balance driveline but there is no universal cure.
4) Exhaust drone. Only happens with aftermarket exhaust due to what I believe is harmonics resonating in the thinner walled aftermarket systems. Not a big solution at present but not a performance issue.
5) Performance. There is no hesitation in the PSD 7.3 when all is in working order. Any hesitation is an indicator of a problem. By design, if all is in order, at throttle tip in, it simply responds. No excuse such as mileage considerations. This = repair bill.
This is my humble stab at the start of a common. Please feel free to chime in with corrections or additions.
https://www.ford-trucks.com/forums/52...questions.html
Hope this helps.
Old Jan 20, 2010 | 06:43 AM
Izzy351's Avatar
Izzy351
You're in the right place. Pull up a chair and have fun with the best group of folks you'll ever meet on the 'net.
Old Jan 20, 2010 | 07:28 AM
Ponyboychris's Avatar
Ponyboychris
What he said^^^^
We can help you with any problem and/or if you have any extra $$$ to spend on your rig.
Old Jan 20, 2010 | 07:47 AM
riverrat41's Avatar
riverrat41
Welcome.....Good luck with your new truck
Old Jan 20, 2010 | 08:09 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE. This is the only spot to be.
Old Jan 20, 2010 | 08:35 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Welccome !
Old Jan 20, 2010 | 08:37 AM
farmdad's Avatar
farmdad
Welcome to FTE! Lisa's list that Mike developed is a very good guide when looking at a truck. If anything comes up questionable, give us a shout and we will try to help. Maybe one of the Tennessee FTE brothers would be able to check out the truck too to see if anything questionable stands out. Good luck!
Old Jan 20, 2010 | 08:43 AM
rat49f6's Avatar
rat49f6
Welcome to FTE
this group of people will save you a lot of money and steer you in the right direction when you spend just as much as you have saved
Old Jan 20, 2010 | 09:19 AM
corn-dog's Avatar
corn-dog
Thanks All !
Talk soon.
Old Jan 20, 2010 | 09:29 AM
big poppa's Avatar
big poppa
Good luck CD, take some pics if you can, we love pics..
Old Jan 20, 2010 | 09:36 AM
HH60FE's Avatar
HH60FE
Oh yea, corndog, these folks will help you spend your cash!!!!!!
Old Jan 20, 2010 | 09:56 AM
BillyBob69's Avatar
BillyBob69
Welcome Corn Dog.... RUN AWAY!!!! PMS is rampant in these here parts!!!
Actually getting infected is a good thing!
Lots of great people here. Great info and lots to learn
Old Jan 20, 2010 | 10:37 AM
WA.Ranger's Avatar
WA.Ranger
Welcome Corn-Dog, I'm digging the name!
Old Jan 20, 2010 | 11:23 AM
mongo75's Avatar
mongo75
Welcome aboard! Yes, we will help you save $$$ on maintenance, just so you can dump it all into mods!! I think at this point I'm about even....
