Local diesel help needed! No start when cold
I just purchased an 01 PSD and I'm having an issue with it.
It refuses to start when the engine is cold and I haven't plugged it in.
Please read my other thread here so I don't have to repost.
https://www.ford-trucks.com/forums/9...se-help-2.html
I've been working on it non-stop since Sunday morning (ok I slept for a few hours and only eat while I'm on the computer looking for more information).
The thread tell about everything I've done so far, and I update it everything I go out and do something then come inside.
Thanks all!
CrazyKen
Good luck with it.
Thanks for the reply, its funny because I'm on a Jeep forum and most of our activity is at night.
I appreciate the kind words. Have a great evening, and stay dry out there with all this wet stuff falling from the sky!
The second time that I had problems with it not starting was when it was cold outside. If it sat outside at night, it wouldn't start but if I had it in the garage it was warm enough to start. When it sat outside, I would plug it in at night and then it would start in the morning. I had to replace the glowpugs and the problem was solved. Now I very rarely let my work truck sit outside at night. I like it better with the cab being warmer at 5:30 in the morning.
I would start with the batteries. The Autozones near me have a bunch of idiots working at them and don't have a clue how to check a battery. If they are over 2 years old, you can probably bet that one of them is bad or will be soon.
When I have 1 battery go bad, I always replace both at the same time. I depend on my truck to start and don't want to mess with replacing one now and one later.
With it starting when it is plugged in, maybe you have a couple of problems(batteries & glowplugs)????????????
I hope that this might help.
Kevin
After doing all the research I've done (over 12 hours and counting on this problem sitting at the computer alone!) I figure I'll go out in the morning after cleaning and fixing the battery terminals and see what happens.
The batteries are the Duralast Gold from Autozone and have a 3 year free replacement on them and I have the information on the warranty so I should be able to get them replaced if I can prove they're bad.
Thanks again!
Kenneth AKA CrazyKen
Kevin what area of Glendale do you live in? I'm near 67th and Camelback.
Go to a different AutoZone and maybe they will test them differently and say they are bad.
These deisel's need both batteries i good condition to get them to start. The batteries should be tested with them seperated from each other.
If you need to have the glowplugs replaced, check pricing at a couple of different places. I had mine replaced at Lou Grubb Ford and a couple of weeks later I got a flyer in the mail from Sanderson Ford that had a special price of about $250 less money.
I live at 43rd Ave and Bell Road, NE corner. I actually live in Phoenix but we have a Glendale mailing address.
If I can be of assistance let me know.
Kevin
Kevin
If I need the glowplugs replaced I will do it myself. I'm not mechanically inept and used to do it for a living so I'd rather get my hands dirty than pay the stealerships (I used to work at one, I understand completely what they do).
I think if it doesn't start in the morning I will have then tested while they are cold and out of the truck!
not much of that down here yet! I was watching Barrett-Jackson earlier and it looked like it was pouring!
Kevin, How is the slick comming along?
I would rather save as much spare time as I can for working on my 63 F100. My 63 is in my profile under My Garage.
Kevin
Very nice looking vehicles, and garage. I wish I had that kind of facilities!
I understand about saving the time when it makes you money, but mine is simply my truck and for now doesn't make me any money so I have to keep it up on a budget.
I didn't realize that Optimas are made in Mexico now, no wonder they are all over at every store now when before they were harder to find and more expensive.
All legacies come to an end eventual, some due to the demiss of the founder, others due to greed.
I think I'd rather go out with a bang personally. (Still have the money rolling until I'm gone and don't care)
if your truck won't start cold but will start when plugged in it is a glow plug issue,
now that can be the glow plug regulator, the engine harness the valve cover harness the under valve cover harness or the glow plugs.
my money is on the glow plugs!
as for batteries, the autozone batteries are made by the same company that makes interstate. if one is week change them both! if your store won't warranty them find another store.
these trucks need 1500 to 2000 amps to get them started, clean cables is a must!
if all else fails my shop is in Chino Valley, PM me for my shop rate if needed. If you don't want to come this far call Nate at Strictly Diesel 480-922-8768. his shop is by the Scottsdale airport. tell him Bart from Diamond K sent you. he is top notch and honest!
Thanks for the information! I'm going to go out very shortly and see if cleaning/replacing cable termials yesterday had any effect.
If I get all the glow plugs to check withing OHMs range would they still not heat up?
I know the previous owner told me yesterday that he replaced them about 60K miles ago/2 years. With as little as we need to use them here (to start up) I'd think they'd last longer but I really don't know.
What is the glow plug regulator? That is one I haven't come across in my searching. Where is it located and how do I test it?
Thanks a ton!
at 60k miles the glow plugs should be good if they installed motorcraft (beru)plugs. if not get them out,
also don't be fooled by the wait to start light on a ford it is just a light bulb on a timer! this morning my light went out at the same time as always but I waited 45 seconds and it fired right up. it will not start when the light goes out when it is this cold.
you can watch your volt meter and see how long the glow plugs cycle.
also too thick of oil will make it hard to start cold, it will take longer for the HPOP to build up enough pressure in the oil rails.
but regardless I change them every 3 years and use them in older trucks and tractors until the die.
these trucks need enough amps to heat the glow plugs, and than have 1,500 amps to spin the engine fast enough for the HPOP to build 900lbs (iirc) of oil pressure before it will start
