WANTED USED *E7TE* HEADS/ good con. please
Old Jan 19, 2010 | 08:23 PM
Big-old-460's Avatar
Big-old-460
Exclamation WANTED USED *E7TE* HEADS/ good con. please
I need these heads as soon as possible atm I can not find them.. and i will just rebuild my heads to save money ..
As of right now No junk yards IN my STATE even have these available and i can not drive my truck anymore in tell I locate these heads.. ANd they HAVE to have the same Number ¬7TE also i would like to point on there is none available online atm.. again thank you for your time...
Jayson
please contact me via email at Calijayson79@yahoo.com thxs
Old Jan 19, 2010 | 11:33 PM
Big-old-460
/evening Bump
Old Jan 20, 2010 | 01:08 PM
Big-old-460
/morning bump... /wave hi f.t.e members
Old Jan 20, 2010 | 01:32 PM
rla2005's Avatar
rla2005
F7TE is the GT40 casting correct? Sorry for my ignorance, but I am not that savvy on casting numbers other than the crappy E7TEs I have my '92 5.8L engine.
lmd91343's Avatar
lmd91343
F7TE for a 460?
Are you in So Cal?
Are those small windsor heads?
I've been to a shop in the SF Valley that has those in stock. They must have had 20 pairs on the shelf. I have a pair that I am enlarging and smoothing the exhaust ports and enlarging the intake ports. I thought they are easy to find.
If you are local I'll look up those shops.
Old Jan 20, 2010 | 01:35 PM
lew52's Avatar
lew52
Yeah i think F7s are GT-40s ...Lew
Old Jan 20, 2010 | 01:46 PM
rla2005's Avatar
rla2005
I have been searching on casting numbers. I found some references of F7TE for GT40 and now a few 7.5L heads.
I'm so confused.....
Old Jan 23, 2010 | 11:56 AM
Big-old-460
Originally Posted by lmd91343
F7TE for a 460?
Are you in So Cal?
yes there the casting number on my 460 ford truck as it is there long block heads its just what the casting number is i gotta match it .. can you help send me a privet msg if you can
Old Jan 23, 2010 | 12:06 PM
lmd91343's Avatar
lmd91343
pm sent...............
Old Jan 23, 2010 | 06:54 PM
Big-old-460
UPDATED NEED E7TE HEADS AS SOON AS POSSIBLE sry I do not need F7tes
Old Jan 25, 2010 | 05:15 PM
lmd91343's Avatar
lmd91343
Jayson,
I sent you a pm with the machine shop info we spoke of and a speed shop that sells 460 blocks, long blocks, build kits and heads. They also have a machine shop.
Check out their Giant special 552 cid 12:1 compression or the 509 cid dinosaur special.
Keep us posted.
Good luck,
slamin79
Jun 24, 2010 10:36 PM
deerjrky
Mar 6, 2008 01:33 PM
mjpennella
1983 - 2012 Ranger & B-Series
Sep 7, 2007 10:06 PM
