Need help removing turbo
Old Jan 21, 2010 | 04:59 AM
Copedawg's Avatar
Copedawg
Originally Posted by stewart460
dont mean to steal the thread but ive asked this question a few times and no one ever answers how do you know if your modle is a cali model ( i'm sure it has to do with the vin right?)
Stew, I am sure there is a way to tell by the VIN but I don't know what it is (I would like to know though).
You can tell if it is a Cali model by the black (UFO) disc on the fuel pump (maybe 2-2.5" diameter). I believe it will have "BOSCH" printed on it. ALSO, it may have a "Cali" sticker under the hood (I say may b/c mine is a Cali but it doesn't have the sticker.....anymore).
If you do have a Cali model there are some things you should know:
Don't do the FPR shim.....you already have enough pressure. If you do this is will wear out you fuel pump VERY quickly.
You have split injectors. So if you change the injectors ask here and the vendor if the new injectors will work on a Cali model.
You have a PCM that is programmed differently. So if you change the PCM ask here and the vendor if the new injectors will work on a Cali model.
If you get a chip or a tune I believe the Cali will factor in so be sure the vendor knows.
I am sure there are some other things but I believe these are the biggies.
1976rustbucket
Nov 29, 2024 09:36 AM
Hotwheelbill
Jan 15, 2014 05:56 AM
damons
20
Jul 16, 2012 08:43 PM
jeter
Aug 1, 2010 04:32 PM
powerstroke6ltr
20
Nov 16, 2007 09:09 AM
