HD Headlight Harness Plug Location?
Old Jan 18, 2010 | 01:13 PM
killforfood's Avatar
killforfood
I bought a heavy duty headlight harness with relays for my 97 F350 and need to know where the blue plug connects into the original harness.fficeffice" /><O></O>
<O> </O>
<O></O>
<O> </O>
<O></O>
If somebody has a picture, that would be great.<O></O>
There are a couple plugs of this type under the master brake cylinder that lead into the fuse block but if it’s one of these then I’ll need to rework the harness a bit to reach.<O></O>
<O></O>
I also bought a pair of the Philips 9007 extreme lamps and I'm anxious to see if they stand up to the hype?<O></O>
Old Jan 18, 2010 | 03:48 PM
hijo202's Avatar
hijo202
Headlight Harness
I am going by memory here (it has been about 2 years since I did mine), but, the blue plug gets plugged into the drivers side factory headlight plug and the factory passengers side does not plug into anything (just dangles there - I wrapped it up and taped it to prevent debris from getting into it).
- Unplug the 2 factory lamp plugs from the headlamps
- Plug in the the black plugs (from new harness) to the headlamps bulbs
- Plug in the blue plug (from new harness) into the drivers side factory lamp plug
- Wire up the relay / ground
I immediately noticed a huge difference in my headlamp performance. I did the same for my '77 CJ-7 as well. Now your headlamp on/off only activates the relay and not the lamps themselves, thus allowing full current to go to the lamps.
I hope this helps you out and doesn't confuse you.
Old Jan 18, 2010 | 04:02 PM
chicagodragon's Avatar
chicagodragon
this makes the a lot of difference? does it come with the relays?
Old Jan 18, 2010 | 04:11 PM
joe_13894's Avatar
joe_13894
The difference is huge. I just bought two relays from NAPA and wired my own.
Old Jan 18, 2010 | 09:04 PM
killforfood
hijo202,
Thanks for the answer, That makes total sense and will be much simpler than what I had in mind.
The instructions were written in Chinglish and I thought I was supposed to be tapping in somewhere up stream.
Yes it comes with two relays.
I'll probably flip the harness over and plug into the pasenger side.
That way I can tap my hot leads into the hot side of the glow plug relay.
The instructions say to bolt them to the battery terminal but I could see them being eaten up with acid in just a couple years.
Old Jan 19, 2010 | 12:15 AM
joe_13894's Avatar
joe_13894
I wired mine in at the starter solenoid. That's where the glow plug relay, alternator and under hood fuse box all get their feed from.
Don't forget a fuse.
Old Jan 19, 2010 | 09:59 AM
killforfood
Thanks Joe,
I was looking at the starter relay and calling it the glow plug relay, my bad.
Anyway, that does look like the most sanitary install.
Old Jan 19, 2010 | 11:19 AM
strokin'_tatsch's Avatar
strokin'_tatsch
ok this is the 2nd time i have seen this HD headlight harness. wuts the reason to be switching to the "HD" harness?? just wondering b/c for whatever reason when i turn on my headlights or parking lights my voltage guage drops way down to a point where if i'm running my radio then it will turn off b/c its not getting enough power. come to think of it i'm going to start a new thread on this right now.
Old Jan 19, 2010 | 11:31 AM
madd91's Avatar
madd91
Where did you get you kit from? I have heard about this, and wanted to try it out...
Thanks
Old Jan 19, 2010 | 11:34 AM
madd91's Avatar
madd91
Where did you get your kit from?
Thanks...
Old Jan 19, 2010 | 07:09 PM
hijo202's Avatar
hijo202
Headlight Harness
Here is where I got mine from. I have know others to make their own by going to the junk yard and getting the factory plugs and constructing it just like this one..
Upgraded Headlight Harness for 94 to 04 Ford with 9007 Bulbs
I hope it helps you.
Old Jan 19, 2010 | 08:50 PM
tjbeggs's Avatar
tjbeggs
Travis you have some other major issue! Your headlights should not be able to kill your radio!
The point of this harness is the get full power to the head lights. Stock the head light wiring and relays are too small so you get 2 or 3 less volts to the head lights than your could/should. This harness gets all the voltage possible to the headlights and makes them brighter.
Old Jan 20, 2010 | 09:41 PM
madd91's Avatar
madd91
Does anyone know if you can use this set up with HID headlight kits? I am running a set of HID`S just wasn`t sure if this kit would put out to much voltage to the transformer...
Old Jan 20, 2010 | 10:40 PM
killforfood
I swiped the harness photo from GOS Performance, so I should probably give them credit and a link.
http://www.gosperformance.com/inc/sdetail/1983
The GOS Performance harness appears to be a better quality unit but quite pricy at $69
<O
I bought my harness from LMC Truck for $29 part #47-3662
http://www.lmctruck.com/icatalog/fe/full.aspx?Page=67
<O
The LMC Truck harness is made in <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com</st1:country-region>Taiwan </ST1and came with confusing (to me) “Chinglish" instructions.
<O
Can’t say if it would work with HIDs? I have know idea how they are wired.
Most certainly if the power to the HID transformer takes the painfully long small gage circuitous route through the dash switch then most certainly you could benefit by running it off of a relay.
Old Jan 20, 2010 | 11:42 PM
joe_13894's Avatar
joe_13894
When I opened up my wire harness to add the relays, I found that not only were all of the wires to the headlights tiny little 18 gauge wires, they also have a bunch of excess wire looped up inside the harness. I'm guessing that this was added to drop the voltage to the headlights down enough to keep the cheap #$@$*!! headlamp switch from burning up.
The brightness increase was very noticeable!
