engine shuts off when you turn headlights on
THOUGHT MY POST WAS MY OWN. HIJACKING? NEVER OCCURRED TO ME, DON'T SEE THE POINT IN THAT. I USE ALL CAPS BECAUSE I'M 70 AND CAN BARELY SEE WHEN USING ALL CAPS. UNLESS THERE IS SOME HARD FAST RULE ABOUT IT, OR YOU ARE THE MANAGER OF THIS SITE, THINK YOUR OPINION ABOUT "SHOUTING" MIGHT BE JUST YOURS? DIDN'T COME ON HERE TO BE LECTURED OR DEBATE WITH ANYONE. JUST TRYING TO HELP OTHERS IN MY SAME SITUATION AND GET SOME HELP MY OWN SELF. MORE PHOTOS WOULD HELP. APPRECIATE THE QUICK RESPONSE AND HELPFUL LINKS.
And unless you clicked "Start a new thread", you tacked your post of the end of an existing thread. There's no need to create continuity in a 13 year old threads.
Trying to diagnose and repair vehicles over the internet is not an easy task. Simple, clear, easy-to-read sentences with proper punctuation is important. TYPING IN ALL CAPS IS DISRUPTIVE.
Youre a new member here, asking for help. We are here to help you fix your problem FOR FREE. The least you can do is follow some standard internet courtesies.
I also linked you to a thread that has the same symptoms you're describing. Did you read it?
I GOT TO TELL YOU...I FIND THIS A LITTLE MORE TEDIOUS AND BORING, OUTRIGHT WHINY! THOUGHT YOU WERE A BUNCH OF FORD TRUCK GUYS, NOT LITERARY *****. I SEE LANCE USING LARGER LETTERING IN BLUE AND RED THAN I'M USING. ALL OVER THE PLACE. THINK I'LL JUST DROP OFF THE SITE, DON'T NEED THIS BANTER.
I am a bit older than @EMacD and I solved the issue by getting pair of "Readers" about a 3.0 power.
I have a stubborn old friend who types in cap's regardless of how many times he is reminded..
Not my circus, Not my monkeys.
____________
Back to the head light issues.
Looking at the photo's there is a ton of Up-fitter wires and connectors at the battery terminal..... Why ? Are you running stuff in the camper off of the battery? If so, put a battery in the camper.
On several of my older model Ford trucks I found "after market" relays that ran an assortment of things like head lights, work lights, stereo equipment.
I hate to suggest adding more electrical components.... but .... You may have to install a relay off of your head light switch that controls the head lights only. Feed that relay directly off the battery and your head lights will get max amps.
alternator issue is probably due to the "load" being put on it. Can you get a test device similar to an Amprobe to read amps being pulled at the alternator?
Just a few ideas.. Don't kill the messenger.
Hobo
https://www.kleintools.com/catalog/c...anging-400-amp
____________
Hobo
Rusty_Old_F250
Apr 19, 2010 05:24 PM
ford f-200
Electrical Systems/Wiring
Jan 20, 2009 04:46 PM
sigtauenus
Oct 5, 2006 02:02 PM
