injector problem???
Old Jan 19, 2010 | 12:17 PM
johnd7854's Avatar
johnd7854
injector problem???
how do you tell if there is a bad injector, what code and what are the symtoms, where can i buy injectore fairly cheap but good, 2001 f250 7.3 powerstroke,86,000 miles she just started showing a slight miss at idle and motor gets loader as i drive...
Old Jan 19, 2010 | 02:29 PM
RussB's Avatar
RussB
You'll have to start with a injector buzz test I believe ! That will tell you if you have a failed injector !
Old Jan 19, 2010 | 07:43 PM
johnd7854's Avatar
johnd7854
buzz test?? how do you do that
Old Jan 19, 2010 | 07:49 PM
onelionhunter's Avatar
onelionhunter
hmmmm
With only 86000 miles, I wouldn't think you have a bad injector. Possibly your under valve cover harness is coming loose on one side or the other would be a good starting point.
Old Jan 19, 2010 | 08:36 PM
F350-6's Avatar
F350-6
How slight is the miss? Cold, hot, or all the time? Did you recently have any recall work done? Does your check engine light (CEL aka SES) come on?
Old Jan 20, 2010 | 09:22 PM
johnd7854's Avatar
johnd7854
its only when i take off and am driving but at idle it sounds perfect, and its been like this for a while about 3 months cold or hot and no work done recently...and the miss is very small
cory5517
Oct 24, 2013 07:19 AM
JHoffman93
Mar 23, 2013 08:25 PM
Blind Driver
Jan 7, 2013 10:46 PM
mhenneboehle
Apr 2, 2010 09:38 PM
AndeyHall
Mar 3, 2010 08:41 AM
