Noobie with interior question.....
I have a 2003 Renger Edge extra cab with the 60/40 seats. The driver's seat bottom cushion is worn.
Is there a way to fix this without 150.00 bucks at an upholstery shop? Can you just add foam? How easy is it to remove the cushion material from the seat bottom?
On a side note what year explorer buckets are a direct bolt in?
Check out: https://www.ford-trucks.com/forums/1...h-console.html
