Embarassing question:
Old Jan 19, 2010 | 07:38 AM
banjopicker66's Avatar
banjopicker66
Really dumb I think but - How does one remove the HPOP lines?
Is there a special tool or procedure?
Old Jan 19, 2010 | 07:44 AM
DND58's Avatar
DND58
Not dumb at all. Good for everyone to se and refresh. This link to guzzle's site should help.
Replacement O-rings for Ford Diesel Engines
mongo75's Avatar
mongo75
To remove the lines you need a "special" tool, or make your own like most on here do. I took a 1/2" wrench and ground the open end down to a point at the ends, and up to 1/8th" at where the handle meets the open end, that gives you a nice gradual bevel. You carefully wedge your "tool" in between the QD halves on the line, and as you insert it, you wanna start to push-pull the line, til you evnetually have the tool inserted a good ways and the line will pop off, may take some force so don't get too discouraged.
Old Jan 19, 2010 | 07:53 AM
banjopicker66
Thank you all very much!
And thanks to Guzzle for maintaining that information online, too.
Old Jan 19, 2010 | 09:35 AM
canister's Avatar
canister
I bought mine here for $13 + shipping.
https://fordspecialtools.com/Detail.aspx?id=1051
Old Jan 19, 2010 | 09:59 AM
machmedic's Avatar
machmedic
Made my own also. Then had to replace both fittings in HPOP due to broken spring in fitting. International dealer has all the parts.
Old Jan 19, 2010 | 11:04 AM
Izzy351's Avatar
Izzy351
I just use two flat screwdrivers. A little cumbersome, but it's not worth the effort/expense in my case for a special tool.
Old Jan 19, 2010 | 11:27 AM
Pocket's Avatar
Pocket
I also used screwdrivers. Took me about 10 seconds to pop each line off.
