cruise control swap???
Old Jan 18, 2010 | 11:54 PM
bewford's Avatar
bewford
what components makeup the cruise system. i wuold like to put it on my 78. just need to know what to look for as i'm gonna have to piece it together. thanks
Old Jan 19, 2010 | 08:46 AM
moose4x4's Avatar
moose4x4
FTE Emeritus
The manual says::
The speed control system is composed of the OFF-ON switch and the SET-ACCEL and COAST switches, a servo(throttle actuator) assembly, a speed sensor, an amplifier assembly and the necessary wires, linkage, check valve assembly, vacuum reserve tank and vacuum hose to connect the components.
Old Jan 19, 2010 | 08:50 AM
bewford's Avatar
bewford
thank you looks like i got a lot of stuff to find.
Old Jan 19, 2010 | 01:56 PM
compressorguy's Avatar
compressorguy
Try doing a search for "73-79 ford cruise" on eBay. I see the whole package on there from time to time. You might have to replace a component or two, but it would get you the wiring and all the parts.
Old Jan 19, 2010 | 06:38 PM
DaytonaTunnel's Avatar
DaytonaTunnel
Is adding a C/C difficult or easy (if you have all the parts from a donor rig) ? Is it just a matter of plugging in the parts, or if my truck didn't come w/ it, do I have to splice into the woring harness ? Thanks in advance.
Old Jan 22, 2010 | 10:45 AM
pha7env's Avatar
pha7env
what acts as the speed sensor and how does it work?
Old Jan 22, 2010 | 11:40 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
It is a small sensor that attaches in the speedometer cable. If I remember right it uses the Hall Effect to sense the speed. Then the amplifer takes over and varies the vacuum on the servo to pull the throttle.
reamer
50
May 20, 2016 07:01 PM
highoctane74
Mar 17, 2016 01:54 PM
69issofine
Electrical Systems/Wiring
Dec 10, 2014 02:51 PM
ramhunter5877
2004 - 2008 F150
Oct 12, 2014 09:10 PM
