Collapsed Hyd Roller Lifters Q
Old Jan 18, 2010 | 04:43 PM
Scndsin's Avatar
Scndsin
Is it possible to collapse hydraulic lifters from lack of oil pressure to the point of them not being able to "pump" back up after pressure is restored?
Old Jan 18, 2010 | 09:14 PM
Conanski's Avatar
Conanski
Anything is possible but that one isn't too likely.. so what exactly is the story behind this question?
Old Jan 18, 2010 | 10:11 PM
Scndsin's Avatar
Scndsin
Oil pressure was lost for a few min, now the valve train has ratchety-ratchety (as best as I can describe) noise. Pressure is postively restored. No rod knock or piston slap from bottom end.
Old Jan 19, 2010 | 09:33 AM
Conanski's Avatar
Conanski
Why did the motor loose oil pressure? Like I said it's highly unlikely all the lifters would fail so it's more likely they are not getting oil pressure now because of a blockage or that some pushrods became displaced and got bent.
Old Jan 19, 2010 | 11:29 AM
Scndsin's Avatar
Scndsin
PM sent...
Old Jan 19, 2010 | 11:42 AM
lew52's Avatar
lew52
I had a 95 302 roller that did the same thing , after cleaning the pick up & replace oil pump , the lifters pumped back up some but , allways made noise , but ran fine . I replaced the motor so i never took it apart so see what it looked like ...Lew
Doomcrew2123
Jan 11, 2016 02:03 PM
TheGrumpyOldTroll
Sep 6, 2015 04:33 PM
Tonkatoy77
Apr 5, 2014 10:59 PM
79aldean
Mar 21, 2014 10:36 AM
svp_evo
Mar 20, 2014 10:12 PM
