Stock Downpipe
Old Jan 18, 2010 | 12:15 AM
dakotajeep's Avatar
dakotajeep
Stock Downpipe
What is the stock downpipe size? I looked around and havent seen much. I assume its 3" ish.
I plan to go with a 3.5 if thats the case to hopefully improve the EGTs and turbo spool.....but gauges come first!!!
Thanks
Thad
Old Jan 18, 2010 | 08:58 AM
dakotajeep's Avatar
dakotajeep
Is this an unknown question or just way to over-discussed even though I cant find it in a search?
Thad
Old Jan 18, 2010 | 09:06 AM
Maxium4x4's Avatar
Maxium4x4
The stock down pipe is 3 inch with a sort of resonator on the 03, still have mine setting in the corner of the shop.
Old Jan 18, 2010 | 11:13 AM
dakotajeep's Avatar
dakotajeep
Thanks!
A 3.5 might be worth it for the lower EGT's then......gauges....hmmm...
Thad
Old Jan 19, 2010 | 02:46 PM
buckman123's Avatar
buckman123
dakotajeep' how do you like your retread tires? I was thinking about getting some, what kind of mileage are you getting out of them. And how do they do traction wise?
Old Jan 19, 2010 | 05:23 PM
william_04_x's Avatar
william_04_x
your 03 DP will be 3" with a layer of heat wrap around it to cover the spots where it's smashed to 2 1/2"..
Old Jan 19, 2010 | 06:51 PM
dakotajeep's Avatar
dakotajeep
Love them so far! I have about 10,000 miles on them and they are wearing fine. A little fast but even and not pitting or chinking off.....unfortunately I only spend 15% or so of my driving off paved roads so they may wear differently when used primarily off road. Since they are cheap I bought a full sized spare and have been roating that through also. The guys that balanced them when I put them on my 03 said it took alot of weight to balance. Traction wise I have no complaints. The soft rubber holds the road well and icy roads but its still a mud tire. Had them in the mud enroute to a hunting spot yesterday and they performed like a champ in the deeper stuff.
Thanks! Sounds like the there is legitimacy to upgrading the DP!!!
Thad
Dpotts94
23
May 27, 2013 12:30 AM
dakota333
Apr 29, 2013 11:04 PM
strokin71
Feb 5, 2009 05:10 PM
strokin71
Mar 21, 2008 09:55 AM
wrangler76
Feb 7, 2005 06:44 PM
