351m, c, w
351m, c, w
i keep seeing posts about the 351m engine and also about the c and w. i understand the c is for cleveland and w is of wendsor, these being the respective places each was built, i think.
what's the difference between the c and w type engine?
what or how does the m relate to the c and w.?
Guest
Posts: n/a
Guest
Posts: n/a
351m, c, w
>Do I have a 351 or a
>352 and How do I find
>out if it is W or
>C?
>Thanks
If it is original, and your two choices are a 352 or a 351, you would have a 352 in a 65 model. The 352 is an FE motor which is neither a C or a W.
Look at your heads, intake mainfold, and your valve covers. If the valve covers go over onto your intake manifold (in other words the intake is so wide it looks like it complete the head) then you have an FE block.
Clevelands have the block cast out around the timing chain and not a timing chain cover. The Windsors do not have th block cast around the timing chain.
There are quite a few other differences but these are some of the obvious.
Hope this helps
Hio\\\
>out if it is W or
>C?
>Thanks
Hope this helps
Hio\\\
Guest
Posts: n/a
351m, c, w
>think. what's the difference
>engine? what or how does the
>w.?
>w.?
Guest
Posts: n/a
351m, c, w
What I have seen from all the research on my current project is that w has narrow heads very different from the c heads and m heads. Just about the only difference between the w and a 302 is the intake and a half inch more stroke. M has a different bell housing than the 400. and both 400 and 351 M have weak bottom ends... many re-builds don't last that haven't been line bored.
Put a high vol.oil pump on either of these. The application of the M's and 400's were so rare that it is a pain finding parts. But a close examination of the three together and no one would have troubles telling them appart again.
Guest
Posts: n/a
351m, c, w
The 400 and the 351 M share bellhousing bolt pattern. The 351 Cleveland is of the same engine family and it is the one of the three (351C/351M/400 - the 335 engine series) that has a different bellhousing pattern. The 351 C shares its bolt pattern with the 351W and its smaller siblings (302 & 289-most that is - early 289s had a 5 bolt pattern like the 221/260s)
There were actually quite a few 351M/400s produced. The 400s from 1971 through some time in the early 80s and the 351Ms from 1975 until the early 80s. They had a reputation of a smog motor so you do not see a lot of people messing with them today unless it is in the vehicle they have. They can really be awakened by getting rid of the smog junk, some head work, and a few other performance mods. There are also some fixes for the poor oiling in the bottom end (external oil plumbing, restrictors, chamfering of the oil holes in the crank).
The Clevelands are getting quite hard to find these days as they were only produced from late 69 into 73.
You are correct that telling a 351M/400 from a 351 C from a 351W is pretty easy.
Guest
Posts: n/a
351m, c, w
I have a 79 351M for sale. I have about $800 in it and would let it go for 6. It has been bored 40 over, crank turned ten under, heads rebuilt with stronger springs for the 524 lift 272 dur crane cam, high vol. melling oil pump, cam bearings, freeze plugs, needs dist,have new starter too. Interested parties need E-mail me
at jwink6(No Email Addresses In Posts!) Thanks.
