mysterious hole in block - Problem?
Old Jan 17, 2010 | 06:48 PM
srf_windsor's Avatar
srf_windsor
01-17-10-ford-winsor (3) on Flickr - Photo Sharing!
01-17-10-ford-winsor (8) on Flickr - Photo Sharing!
Hello,
After picking up my windsor block from the machinist, I noticed an irregular looking hole in the block. Why would there be a hole in this part of the block? Doesn't the timing chain have to be sealed in order to be lubricated? Does it need to be fixed?
This is my first rebuild. I greatly appreciate your help.
Thanks!
Also, assuming that the hole is not an issue, I will continue by painting the block. Apparently this is from a 1984 ford vehicle. Where can I find out which color is appropriate for this year model? Or should the color of the block match the vehicle I am installing it in? Thanks -
01-17-10-ford-windsor (11) on Flickr - Photo Sharing!
Old Jan 17, 2010 | 07:37 PM
Fomoko1's Avatar
Fomoko1
Hello and welcome aboard.
Any questions check with your machinist as well as with the members in the Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) forum: Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) - Ford Truck Enthusiasts Forums
To me it looks like a normal oil return drain hole but I`m no an expert on this or your other questions.
Join your local CO chapter soon too: Colorado Chapter - Ford Truck Enthusiasts Forums
Old Jan 17, 2010 | 08:59 PM
srf_windsor
Thanks!
Thanks! Will post on that forum.
Old Jan 18, 2010 | 12:17 PM
1Aauto's Avatar
1Aauto
Former Vendor
Welcome to the site.
F350-6
22
Feb 8, 2009 06:54 AM
71fordguy1994
New Member Introductions
Apr 14, 2008 06:51 AM
hmatt1028
Nov 18, 2007 09:55 PM
