i need help
Old Apr 14, 2008 | 05:00 AM
71fordguy1994's Avatar
71fordguy1994
i need help
hello my brethren of the ford i have a problem i have a 351 windsor so i need a transmision i found a small block C6 {four wheel drive ) and a big block C6 (with a long tail shaft ) i tore down the big block C 6 and removed the output shaft and then tore down the small block C 6 a swaped the four wheel drive output shaft for the long output shaft of the big block C6 and reassembled the transmission when i went to bolt the long tailshaft houseing to the small block C 6 there was a gap of about a quarter inch where the houseing wouldnt sit flush does any body know why this happened
Old Apr 14, 2008 | 06:51 AM
Ultramagdan's Avatar
Ultramagdan
Welcome!
Try posting your question in our tranny forum: Clutch,Transmission, Differential, Axle and Transfer Case - Ford Truck Enthusiasts Forums
kevin Britt
Site Announcements
Jun 9, 2019 12:21 AM
srf_windsor
New Member Introductions
Jan 18, 2010 12:17 PM
F350-6
22
Feb 8, 2009 06:54 AM
