lug nut torque
Old Jan 17, 2010 | 06:30 PM
Skullonarm's Avatar
Skullonarm
lug nut torque
Doe's anyone know what the torque is for lug nuts on a 2WD V-10 Excursion with stock aluminum wheels? Doing front rotors and bearings tomorrow and don't want to warp anything from the get go.
Old Jan 17, 2010 | 06:42 PM
EXv10's Avatar
EXv10
I think they are 155 lbs.
Old Jan 17, 2010 | 07:01 PM
havdaddy's Avatar
havdaddy
yes, just looked it up. 155 it is.
Old Jan 17, 2010 | 07:10 PM
Skullonarm's Avatar
Skullonarm
Thanks for that info. Dang I think I've been using 125 ft/lbs. Good info guy's. Never hurts to ask, I don't care how long you've been doing it. (wrenching that is)
Old Jan 17, 2010 | 07:51 PM
Monsta's Avatar
Monsta
Sit. Stay.
155lb ft certainly works! Spec is actually 150-165 lb ft.
I do it in at least a 3 step process.
Finger tight then;
125lb ft (all);
160lb ft (most my trq wrench goes to)
Old Jan 18, 2010 | 03:29 PM
howler4x4's Avatar
howler4x4
Bought tires from a buddy, he installed the tires, I did the wheels.
https://www.ford-trucks.com/forums/9...new-meats.html
He called me a fairy for using a torque wrench
155 lbs/ft
Old Jan 18, 2010 | 09:12 PM
EXv10's Avatar
EXv10
155 lbs/ft
You can call him a fool when his studs snap off.
Old Jan 18, 2010 | 10:29 PM
Stewart_H's Avatar
Stewart_H
Or when they come loose.
Any good tire shop will use torque wrenches now because German specs (gudentite) just doesn't cut it anymore. Plus, like Monsta posted, a two step torque method (three if you count finger tight) is good preventive maintenance to keep from ruining a rotor.
Stewart
Old Jan 18, 2010 | 11:31 PM
Monsta's Avatar
Monsta
Sit. Stay.
I never want to have to post a thread like this...
https://www.ford-trucks.com/forums/9...n-the-hwy.html
Mr J 125
Mar 18, 2022 02:24 PM
Hwilcox
2009 - 2014 F150
27
Jul 4, 2021 05:53 PM
Glockem45
Dec 18, 2016 10:22 PM
codeman2443
May 30, 2015 10:20 PM
rblaine9000
6.4L Power Stroke Diesel
Sep 6, 2011 01:04 PM
