Sponsored by: Real Truck
99 diesel tranny problems....
Old Jan 17, 2010 | 12:17 PM
beaudaniel83's Avatar
beaudaniel83
2wd, 99 f350 7.3, dually , automatic tranny, when i first go everything good, tranny warms up, and i come to a stop it slipps when i try and take off again, can pull it in first and it works like it suppose to, what i mean by slipps is the engine will rev to 1800-2000 rpms brfore truck starts to move and takes a longer time to get up to speed and help would be appreiated....thanks email-beaudaniel83@hotmail.com
Old Jan 17, 2010 | 12:38 PM
Ultramagdan's Avatar
Ultramagdan
Welcome to the site!
I moved your post to the appropriate forum.
Old Jan 17, 2010 | 04:57 PM
martyanderson10's Avatar
martyanderson10
What is the "appropriatte forum" I would like to view responses?
Old Jan 17, 2010 | 05:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
This is the appropriate forum.
I suspect that the seals in the forward clutch are about worn out. Putting the shifter in 1 increases the pressure to the clutch so it works better. When the trans is cold the ATF is thicker so that it doesn't leak past the seals as easily.
