1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
(im a noob) bigger trans for 2000 F250?
Old 01-17-2010, 12:54 AM
stallion91's Avatar
stallion91
stallion91 is offline
my friend has a 2000 F250 with the 7.3L 4WD and his transmission blew out. he says the 4R100 wont be strong enough for the things he pulls.
is there a bigger trans that will bolt up to this engine and will be more heavy duty than the 4R100?
dont ask why hes not posting on here, cause idk...
Old 01-17-2010, 07:01 AM
redford's Avatar
redford
redford is offline
Received 1,628 Likes on 952 Posts
You can't just remove a C-4 and put in a C-6, like back in the 60s and 70s. One of the troubles with today's transmissions is that they are electronically controlled. You can't just swap the transmission, because the computer is the truck is programmed to control a 4R100. If you installed a later model 5R110W (which is a stronger transmission) with the associated computer, you won't have a computer that handles a 7.3L PSD.
But, it isn't that complicated. A 4R100 can be made into a bulletproof transmission with a few upgraded, or a rebuilt and upgraded transmission can be purchased from a number of transmission vendors. A Google search will turn up numerous sources for a rebuilt 4R100 that can easily handle your friend's heavy footed transmission shredding driving.
Old 01-17-2010, 07:03 AM
Dan Jordan's Avatar
Dan Jordan
Dan Jordan is offline
i went through 3 e4od trans in a 96 f350 dually 7.3 i would look in to the after market shops that build your tranny sick. i didn't do it the first time because it cost $700 more that a jasper rebuild. wish i had lasted a couple years then went again. if i had the performance shop do it it would have lasted. good luck
Old 01-17-2010, 07:38 AM
SGnAZ's Avatar
SGnAZ
SGnAZ is offline
Depending on where your friend is,he can go with a BTS or a John Wood tranny
BTW,Welcome to FTE
Old 01-17-2010, 09:36 PM
DOUBLEJACK's Avatar
DOUBLEJACK
DOUBLEJACK is offline
BTS all the way. i went thru 3 transmissions on a 95' F 350 and finally had BTS build me the right one. We just hook up and pull, no worries!
SammiJo
08-04-2014 09:01 AM
diehardstroker
18
07-11-2013 11:37 AM
barthel
03-04-2011 07:27 PM
93PGT
02-14-2010 03:42 PM
Bruised
12-19-2007 10:07 AM
Quick Reply: (im a noob) bigger trans for 2000 F250?
