anybody know if someone sells a 4" or bigger suspension lift for an 02 f-150 with the 7700 package? everywhere i look they wont fit because of the 4r100 trans thats in it, since its bigger it uses a different cross member or something?? i cranked up the torsion bars in it but i still want to lift the truck more... any input would be great!
I'm in the same situation, except it is a '03. Have you had any luck figuring things out? Can you order a F250 light duty? So far I think the only options avalable are the ProComp and RCD.
no i havent found anything yet, i emailed pretty much every suspension lift manufacturer i can think of but only had one response from rough country saying no.. still waiting from others... i havent seen any body offer anything to an f250 light duty so im not sure..
i got an email from both RCD and ProComp, RCD says they have a kit for a 24" trans pan, and ProComp says they have a kit for a 26" trans pan... so i guess measure the transmition pan and go from there...
What did you find out about the size of your pan? Crawled under there today an the actual pan is about 13"x20", if I include part of the transmission in that same space it is about 27".
