Sponsored by: Real Truck
Suggestions?!
Old Dec 17, 2007 | 05:57 PM
Bruised's Avatar
Bruised
Suggestions?!
I'm looking at buying a 2000 Ford F250 7.3 auto with 220,000 miles. The truck is well taken car of but I'm pretty sure that the tranny has never had rebuild. I know he changes the fluid and filters religeously and he is the second owner of the truck. If I buy this truck should I be afraid to throw on a Dp tuner? Also the 4r100 has no issues and my friend has towed 10k pounds with the truck but what do you guys suggest with making the tranny survive. I've read to put a bigger tranny cooler on it but what else?! Thanks in advance!
<!-- / message -->
Old Dec 17, 2007 | 11:00 PM
Bruised's Avatar
Bruised
Anyone........?
Old Dec 17, 2007 | 11:26 PM
biz4two's Avatar
biz4two
Arrow
IMO...with 220,000 on a 4R100 tranny is pretty good. Keeping the 7.3L PSD all OEM stock is my best advice for having the tranny live. There are several known issues with the 4R100 in stock form...visit this site and read up on the differences...from OEM stock to aftermarket rebuild. (Monster Box and Stock Comparison)...
http://www.factorytechtransmissions....PROD&ProdID=15
However, if you plan on a tuner, then plan on the budget for a new tranny. Age and miles are both NOT on your side.
Good luck...
biz
Old Dec 18, 2007 | 07:18 AM
Bruised's Avatar
Bruised
So If I decide to get the truck just keep it stock and tow with it for a year while saving for an upgraded 4R100?! He needs to unload it so maybe I'll make a deal with him that if the tranny goes within a year he has to pay for half of a new Tranny!! He's only asking $10,500 for it and its clean. Thanks for the help!
Old Dec 18, 2007 | 08:27 AM
RogueSpear2023's Avatar
RogueSpear2023
You should have a problem upgrading it with a DP tuner, although if you do make sure you get guages first, tranny and PYRO, 4" exhaust, new intake most like the 6637 or AIS, then get a BTS valve body(don't get a banks controller) and if your going to pull heavy loads you will want to get a bigger tranny cooler. Now after you have done all this you can get a DP tuner. But there are many trannys out there with DP tuners that are just fine. Just make sure you don't overheat it, and change fluids regularly and you should be fine. I wouldn't worry to much about the 4r100, its a great transmission, not as good as the torqueshift, but you can't have everything. Just do the support mods first, and you shouldn't have any problems.
Old Dec 18, 2007 | 11:41 PM
Bruised's Avatar
Bruised
Thanks! Very good info! A couple more questions...Where can I purchase a Bts valve body kit and what should I expect to pay for it? Also do you have any info as what tranny cooler to go with and what they run?
Old Dec 19, 2007 | 12:52 AM
biz4two's Avatar
biz4two
Arrow
I always recommend either BTS or FactoryTech in regards to both valve bodies and tranny. Here is a link to a FactoryTech install...and just how easy it is. http://www.supermotors.net/clubs/for...ll_6/index.php
http://www.brianstruckshop.com/
Sorry...cannot help with exact cost, but remember something in the $240+ range.
A really good upgrade mod for the 7.3L PSD and 4R100 tranny is going with a '05-'07 OEM 6.0L PSD tranny cooler. Some mods necessary, so do a search in the 7.3L PSD forum...and you will find lots of info.
Hope this helps...
biz
Old Dec 19, 2007 | 01:54 AM
Bruised's Avatar
Bruised
Looks like the Factory Tech valve body is only going to run $225.00 not bad for crisp shift points! Thanks for the help. I'll have to look into tranny coolers!
Thanks guys!
Old Dec 19, 2007 | 01:58 AM
036.0's Avatar
036.0
sory to hijack but is a valve body worth doing on a truck with almost 100k or should i wait for the trans to go and replace it with a stronger one??
thanks
Old Dec 19, 2007 | 10:07 AM
RogueSpear2023
thanks
Replace it now before the tranny goes, 100k is hardly broke in on a truck like this, I would definatly put one in if you have a chip or are pulling heavy loads regularly. There only about $200-300, a very good and cheap upgrade, if you have $4000 just laying around though I would go with a BTS tranny now, or get a BTS VB and if the tranny does go, Brian will give you credit for the VB off of a one of his new transmissions, that way you can't lose. Your always better off fixing problems before they become serious ones and take something else out with them. Many transmissions will last far past 200k, the 4R100 isn't a real common problem, unless you pull a lot of weight every day, or you have a tuner. Otherwise they are normally very good transmissions
mudguts
Jan 27, 2012 08:51 PM
79ford302
Oct 2, 2010 11:36 AM
1957F100
29
Sep 2, 2008 09:47 AM
fordfaninIL.
Mar 15, 2007 06:11 PM
wombodtranger
Kansas Chapter
Sep 20, 2004 07:09 PM
