Sponsored by: Kumho
Wandering Issue
Old Jan 16, 2010 | 05:06 PM
Fandini's Avatar
Fandini
Wandering Issue
I've had this problem since the truck rolled off the dealers lot in July 2006. I've since put new tires on the truck, added dual steering stabilizers, and had it aligned at least 4 times. I even had the tech add a little toe in as was suggested to me. Nothing has helped. My dual stabilizer shocks are pro comps and the shocks are not pressurized which makes me wonder if they are worth a crap since I can EASILY compress them and pull them out. I've even thought about switching out the suspension bushings for aftermarket Poly bushings with the grease zerks. I don't know what else to do. My truck is a 2006 F-350 CC, LB, SRW with the FX4 package and now has 55,000 miles. Anybody run into this?
Old Jan 17, 2010 | 05:56 AM
senix's Avatar
senix
usually the things you have done help. What about rotating the tires. I am sure you've done that already as well but thought I would mention it.
Have you looked at your steering box? could there be excessive play in the steering?
Old Jan 17, 2010 | 06:58 AM
Lazy K's Avatar
Lazy K
My thoughts. Loose wheel bearing/s, play in ball joints/tie rod ends/steering box, unequal tire pressures, incorrect castor, weak front spring.
Old Jan 17, 2010 | 10:45 AM
Fandini's Avatar
Fandini
everything you mentioned has been checked by the dealership. They tell me castor can't be adjusted in small increments. I had a freind of mine suggest laying the castor back a little, but the alignment tech said that small adjustments aren't possible. I haven't looked at the steering box, but I think the dealership has, I was told that they checked out everything but since I wasn't there I don't know. I've not heard of a weak spring..... but I don't see any obvious signs. Does anybody have any thoughts as to how hard or easy it should be to compress the stabilizer shocks. Mine compress REAL easy. I would think that there should be substantial resistance. How about polyurethane bushings on the suspension components. I personally think the castor could use some tweeking but I don't think that's possible.
Old Jan 17, 2010 | 12:04 PM
senix's Avatar
senix
my stabilzer shocks are not real hard. I mean there is resistance but not a tremendous amount. I am running dual skyjackers
Old Jan 17, 2010 | 01:11 PM
clint1507's Avatar
clint1507
wandering issue
Im having the same problems as you going back to the shop again just steering box and what else they can find its driving me nuts had tie rods fixed new steering shock and new u joints they say every thing else is good so they are having it back and i hope its fixed this time
Old Jan 17, 2010 | 03:36 PM
Fandini's Avatar
Fandini
Senix, I have a procomp dual setup, but I like the look of yours better. I just think that there should be a good amount of resistance with those shocks. The OEM unit is real hard to move. Has anybody tried the Polyurethane bushings, or would that be a waste of money? Does anybody know if I can just replace the stabilizer shocks with a different brand that might be of better quality?
Old Jan 18, 2010 | 06:12 AM
senix's Avatar
senix
you can just do a replacement to the shocks..I would suggest the same type I have for the stabilizer. Had them all around on my 06. Was a good setup!
A/Ox4
Jul 5, 2014 06:30 PM
1977F1504X4AUBURN
Dec 19, 2010 07:06 PM
Headviking
Oct 18, 2009 09:56 PM
cixelsyd
1997 - 2003 F150
Jul 15, 2009 10:00 PM
S5snake
Dec 6, 2007 08:20 PM
