Question on booster pump install
Old Jan 16, 2010 | 11:09 AM
mueckster's Avatar
mueckster
This how I have mine set up. There is a mini blade type fuse holder with a 3 amp fuse near the pump. I have a relay under the hood near the power distribution box to supply the pump's power and is triggered by a wire coming from the OEM pump's wiring at the harness plug.
I have since added w/s wiper motor grommets to the pump's mount to reduce the noise from vibration and currently using a shorter filter that doesn't extend below the frame.
Old Jan 16, 2010 | 11:10 AM
kirkharrod's Avatar
kirkharrod
You can get a Bosch stocker replacement pump on eBay for $99.95.
Bosch F81 U-9350-AA 0580464074 Ford Diesel Fuel Pump : eBay Motors (item 390108696313 end time Jan-19-10 06:35:39 PST)
Old Jan 16, 2010 | 11:19 AM
Izzy351's Avatar
Izzy351
I don't think it's going to help with power & mileage, honestly. You've done the in-tank mods already, so that fixes the air problem. Do the CCK, FRx, or RR and be done. The other stuff is (way) overkill IMHO.
Old Jan 16, 2010 | 05:44 PM
puffen:D's Avatar
puffen:D
mueckster, your running your pump before the filter? You still have the in-tank screen or small inline or just letting your pump eat anything that might come thru?
Old Jan 16, 2010 | 05:46 PM
puffen:D's Avatar
puffen:D
By the way, I have the same pump. How long has your's been in service?
Old Jan 16, 2010 | 06:00 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
i did the carter lift pump mod on my truck and then a month later put the walbro gsl 392 on there to replace the stock pump and had to take the carter back off as it was a restriction for the walbro unit.....
Old Jan 16, 2010 | 07:19 PM
puffen:D's Avatar
puffen:D
Anybody running a lift or booster pump notice any improvements that made the instillation worthwhile?
Old Jan 16, 2010 | 07:24 PM
Izzy351's Avatar
Izzy351
I have a bit of an update. I got my fuel pressure gauge put in finally, and I'm dropping *a lot* of pressure at WOT. Like into the low 30s. I'll put the RR in tomorrow and see what that does. Right now, I still have the DFA CCK in, and was waiting to put the gauge on before I did the RR conversion. I put it in my sig a while back, but never got around to putting it on. I'll update what I see after the RR install tomorrow...
Old Jan 16, 2010 | 07:55 PM
spdmpo's Avatar
spdmpo
So you're saying a lift pump might not be overkill after all?
Old Jan 16, 2010 | 10:24 PM
mueckster's Avatar
mueckster
I'm still running the stock screen on the foot of the pickup tube in the tank. The fuel pump also has a screen in the inlet of it. I have been running this setup for about 1 1/2 yrs now. Had the Carter pump with a small inline filter before the stock pump until it started making a rattling sound and I switched to the current one. Had the Carter for about the same amount of time. I was more concerned with the booster pump failure sending crap into the high pressure fuel pump. This booster pump is a ProComp 115 gph vane type pump that comes with 2 relief springs. I have the 3-4 psi one on there. It will still allow fuel to pass thru it if it fails. I tried it by disconnecting the power to see if it would. It may restrict volume somewhat, if failed, but I would still be able to run without it.
I need to hook up my fuel pressure tester and check it at WOT. Still running the stock pump with over 160k miles on the clock.
Old Jan 16, 2010 | 10:33 PM
Izzy351's Avatar
Izzy351
No. I'm saying I need to get my RR put on. If it still drops too much, then I'm going with the Walbro.
Old Jan 17, 2010 | 08:42 AM
puffen:D's Avatar
puffen:D
I didn't think about the possibilty of the booster blow'n chunks to the hi pressure but that's a good thought. I put the higher pressure spring in my pump but you've been running the other with no problems I might change it back out. I had problems with low pressure at WOT and was running the shim. I tried larger shim with no increase in pressure. When I did the FRx I noticed the FPR rubber parts had shrunk and could be leaking pressure by, I put a kit in and that's when my OEM pump gave-up the ghost.
Mueckster, it looks like you have your in-line fuse down by your pump, just for safety sakes I would put it up where your power source tap is at, if you get a short between your battery and fuse it could start a fire. So did you notice any difference after doing the booster pump?
Old Jan 17, 2010 | 09:07 AM
  #28
mueckster's Avatar
mueckster
I have another fuse in the power supply near the additional fuel pump relay where I tapped the power at the power distribution box. Thanks for the concern though. The fuse by the pump was there first when I paralleled into the OEM pumps wiring. But, later I added the relay and its own separate power source for less voltage drop.
I actually had a homebuilt cyclonic air/fuel separator on the mounting bracket in my pics. The first pump I had pressurized the bowl and had a return to the brass tee you will notice in the pics. I took this off because of leaking issues and the installation of my homebuilt CCK made it unnecessary.
I didn't do any before and after pressure tests at the time. I need to do a WOT pressure drop test soon and see how things are. I am looking at adding a fuel pressure gauge inside the truck.
Old Jan 17, 2010 | 09:34 AM
  #29
puffen:D's Avatar
puffen:D
Yea, I saw that T in the line and was wondering what it was for. I was actually thinking of doing something similer running the boost pump to the filter with a orficed return off the top of the filter housing back to the tank but with doing the in-tank mod. it shouldn't be necessary.
In regards to the in-tank mod., does removing the mixer and putting the return farther away from the pick-up change gelling issues when it's in the minuses?
Old Jan 17, 2010 | 09:41 AM
  #30
mueckster's Avatar
mueckster
No gelling issues where I'm at, so I can't really answer that. I know there are plenty up north that have done the in-tanks, but I don't think gelling problems are caused by them.
CCK or RR would benefit you more than the orifice and return at the in frame filter. Without some sort of A/F separator, it wouldn't do much.
