Dual Battery setup
Old Jan 15, 2010 | 11:16 PM
jrodimus's Avatar
jrodimus
Dual Battery setup
Is there a good thread allready posted for a dual battery setup?
I just had a camper given to me and think some re-wiring is in order. The dual battery would help for the camper as well as the winch.
Old Jan 16, 2010 | 12:19 AM
Growl60's Avatar
Growl60
First off, what year? engine?
Old Jan 16, 2010 | 12:36 AM
jrodimus's Avatar
jrodimus
1990 f250HD, 460, 5sp ZF no AC.
Old Jan 16, 2010 | 12:42 AM
LCAM-01XA's Avatar
LCAM-01XA
Go take a look at any '83-'94 Ford diesel truck at your local junkyard, then grab the driver-side battery tray off it and wire up the batteries just like the diesel was done - both positive terminals hooked up together and to the starter relay on the fender (or directly to the alternator charging cable), both negative terminals wired to the engine block. If you don't have a 3G alternator yet, now's the time to install one. I have a 130amp 3G charging the passenger-side battery (and from there the driver-side one too) directly through a 1/0 Welding cable and a 175mp MegaFuse, the starter relay is powered through a very short 4-gauge amplifier cable, I got enough lights on the truck to make the alternator darn near glow from heating up and the big-cable setup works great for me.
Old Jan 16, 2010 | 09:22 AM
jrodimus's Avatar
jrodimus
I was hoping for more of an isolated dual setup so that if I kill one battery with the camper/winch, I always have power in the other. Maybe your suggestion would work that way and I just dont know any better. LOL
Old Jan 16, 2010 | 09:31 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...d-battery.html have a read right the way through this thread. Some great info, including wiring diagram.
Old Jan 16, 2010 | 09:45 AM
jrodimus's Avatar
jrodimus
Good stuff! Just what I was looking for! Cheers!
Old Jan 16, 2010 | 03:33 PM
LCAM-01XA's Avatar
LCAM-01XA
I see, well with the huge amounts my diesel is drawing at startup I have to have two batteries in parallel all the time, your situation tho would definitely benefit from having a battery isolator of some sort. However, as mentioned in the other thread, if you go with a relay-type isolator make sure the relay is of the continuous-duty type, the regular starter relay that goes on the fender ain't continuous duty and so cannot handle high currents for prolonged periods of time.
Old Jan 16, 2010 | 07:18 PM
jrodimus's Avatar
jrodimus
I will certianly use a different relay. Thanks for the post.
D-rat
27
May 3, 2018 12:52 PM
79 F-150 Stone
Mar 18, 2017 03:24 PM
good to doo
33
Mar 4, 2017 11:38 AM
Im50fast
Aug 11, 2016 11:47 AM
Dace
22
Jun 9, 2016 12:50 AM
