3g alternator overcharging
Old Jan 15, 2010 | 08:50 PM
TourqueRise's Avatar
TourqueRise
I just converted my 91 f250 7.3 diesel to a 130 amp 3g alternator from a 1993 Taurus 3.8. This alternator is charging 14.9 volts with all loads on, and the same with no loads on. The voltage is the same from idle all the way up to 3000 rpms. I rebuilt the alternator with a new regulator, brushes, and bearings to see if it was the regulator, but it charges the exact same voltage. I used the wiring from the Taurus, and hooked everything up properly I think. Is this high for this alternator or is it normal? Thanks.
Old Jan 15, 2010 | 08:55 PM
johnboggs21's Avatar
johnboggs21
14.9 sounds right to me, but what do i know lol. It has to be more than battery voltage which is 12.6 or it wouldn't charge them, so it sounds fine to me.
Old Jan 15, 2010 | 09:04 PM
kenpobuck's Avatar
kenpobuck
That is what my 86 alt charges at any thing above idle. I don't think it is to high as I have never had anything blow or get hot.
Old Jan 16, 2010 | 12:07 AM
LCAM-01XA's Avatar
LCAM-01XA
same here, I usually run at 14.6V at anything over high idle.
Old Jan 16, 2010 | 09:40 AM
timothyr's Avatar
timothyr
from lots of experience with automotive electrical 14.4~15 is good...above 15.2 keep an eye on things.
Honestly in my mind if you are getting 14.9 full load at idle, and things stay the same at 1500rpm no load I would be very happy....that says on the cold snowy night you wont run out of power while waiting for the wreck to be cleared up the road.
Old Jan 16, 2010 | 08:29 PM
TourqueRise
Ill keep an eye on it, and hopefully it doesn't go any higher. Thanks for the help.
Old Jan 16, 2010 | 08:35 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
That is fine.
My alternator is seriously overcharging it push 20 volts at idle. Didn't know that for 4 days when we own 95 F250.
Old Jan 16, 2010 | 08:37 PM
starmilt's Avatar
starmilt
If your truck starts smelling like rotten eggs it is overcharging and the battery is getting close to blowing.
ctubutis
'80-'86 HOWTO's
Nov 12, 2023 12:34 PM
78fordguy
43
Jun 15, 2019 12:32 PM
koldham
16
Apr 22, 2017 08:49 AM
F-250 restorer
Aug 28, 2016 12:59 PM
VaFordman26
57
Apr 9, 2015 05:32 PM
