Offroad & 4x4
Transfer case question
Old Jan 15, 2010 | 06:59 PM
salmonslayer204's Avatar
salmonslayer204
I tried posting this question in the 86-96 section for older f-150s and larger but I haven't had much luck there.
Maybe you 4x4 guys/gals can help me out.
I am doing a rebuild on my transfercase (Borg Warner 1356) in my 88 diesel single cab and I have been reading some stuff that concerns me a bit. My case is not braced and I am running 6" rear blocks and 38" tires. I have heard that an unbraced case is very suceptible to damage from axlewrap, which I am sure I have.
My question is: should I fab up a brace for the transfer case? If so, should I use rubber bushings so that is can flex a bit as I twist up the frame off-road, or can it be a solid mount?
Thanks for your advice.
Old Jan 15, 2010 | 09:22 PM
mark a.'s Avatar
mark a.
I'd get a set of ladder bars on it if you haven't already done so. Those blocks will wind it up bad.
Old Jan 16, 2010 | 12:50 AM
Prozon's Avatar
Prozon
I do not think that you will have any problems with your transfercase regarding axle wrap. I have the same t-case with 37's and I have yet to have a problem. I've snapped u-joints and such, but never a t-case issue. The 13-56 isn't really a heavy T-case, I can see an NP-205 needing a brace, but with the 13-56 case, you should be fine.
Old Jan 16, 2010 | 01:48 AM
Bender99's Avatar
Bender99
I agree with getting the axle wrap under control, win win
Old Jan 16, 2010 | 10:49 PM
Prozon's Avatar
Prozon
Yes. It would be a good idea to get the axle wrap under control, but it won't hurt your t-case.
FourXFord2
1978 - 1996 Big Bronco
18
Jun 12, 2023 12:17 PM
Gear619
Feb 23, 2015 11:06 PM
SCRebel
20
Nov 19, 2011 09:13 AM
driptorch970
2009 - 2014 F150
Dec 21, 2010 11:39 AM
ya sure
Jun 1, 2003 11:42 PM
