STILL HAS MISS
Old Jan 15, 2010 | 06:41 PM
fordpride's Avatar
fordpride
STILL HAS MISS
2 days ago she started to miss real bad at highway speed. Got home pulled code P0034 CPS changed it truck ran 90% better but stil has a miss only at highway speeds it idles real good revs up real good in neutral.when it starts to miss if i smash it to the floor it clears up for a little then comes back. I no my fuel pump is starting to leak but if that was it then i think it would get worst when i hammer down on it.the truck has just been completely service. what do ya'll think any help will be greatly appreciated THANKS!!!!
Old Jan 15, 2010 | 09:37 PM
fordpride's Avatar
fordpride
could an IDM cause it to miss
Old Jan 15, 2010 | 10:47 PM
RRranch's Avatar
RRranch
If your fuel pump is leaking it can and probably will cause a miss. Diesels don't like air in the lines or low fuel pressure.
Old Jan 15, 2010 | 11:16 PM
95_Dually's Avatar
95_Dually
X2 what RRranch said. Fix the known fuel pump problem and see if this fixes the miss. Ya need to fix the fuel pump anyway.
Old Jan 15, 2010 | 11:17 PM
fordpride's Avatar
fordpride
if its the pump then how come when ihammer down on it it clears up. and will a 99 SD IDM work on a 97 a buddy has 1 and i will try it just to make sure it's not the IDM
Old Jan 15, 2010 | 11:22 PM
95_Dually's Avatar
95_Dually
Reading your signature you have 72psi fuel pressure. That is more than enough to properly run your truck. I am not sure if the IDM is the same or not. Take your buddies IDM off of his truck and see if it runs better.
fordpride's Avatar
fordpride
the pump was leaking before the bad CPS and i didn't have the miss. i'm going to return the CPS tomorrow and get 1 more just to make sure i din't get a bad one you know how NAPA parts can be LOL i was reading some old post and found that there is a gray one and a black ane whats the diff.
Old Jan 15, 2010 | 11:31 PM
95_Dually's Avatar
95_Dually
I don't know the difference other than International has the black one. My best friend works there and he can get me those. So the next time I need a spare, I will get it from him.
Old Jan 16, 2010 | 12:05 AM
strokin'_tatsch's Avatar
strokin'_tatsch
your truck being a '97 should have the grey CPS. GO TO FORD!!! not napa. there was a recall on the '97 CPS and if it hasn't been taken in yet then its free.
the '94.5-'95s use the black CPS. ask for a '97 at ford and get a grey. ask for a '95 and get a black. did it. asked for both at the same time. haha
Old Jan 23, 2010 | 05:02 PM
Bird Hunter's Avatar
Bird Hunter
My '95 started off with an occasional miss and later progressed to dying at highway speeds for no reason. I changed the CPS with one I got online and the problem got worse. I got one from the local dealership and the truck ran fine. Apparently these can die at any time and even be bad out of the box. I'd try changing it one more time.
Old Jan 23, 2010 | 08:11 PM
fordpride's Avatar
fordpride
igot it fix it was the TPS cutting out.and i change the cps 4times
Old Jan 23, 2010 | 10:35 PM
fuelman's Avatar
fuelman
Glad you got it fixed.To answer your question on the IDM,Yes it will work in the earlier trucks.As a matter of fact alot of guys get the SD ones cuz they operate on higher voltage,which is supposed to help fire the injector better.Many guys get "modded" ones that are even higher than the SDs
Robrt32
Feb 19, 2015 12:31 PM
LFDavidson
Jan 26, 2015 09:55 AM
francissmith14
Modular V8 (4.6L, 5.4L)
Sep 27, 2014 07:45 AM
johnsteph515
Oct 14, 2004 07:55 PM
