Fuel gage worked then stopped and now its not again??? Anyideas what I should look for??? I changed the batt cables, could I be missing a ground or something? 95 F250 w/ 460
what about your fuel pump sensor ? should be inside the tank ? might be messed up ? do you have a chiliton maunal ?
Most of the truck sending units that I have seen have a brass barrel shaped float, they can get a leak and sink.
When they first start to leak they can give sporadic readings as they half sink, they float up and down funny.
They just clip into a loop on the end of the float lever arm.
I just replace one like that last week in a 93.
Reason: added explanation
