Code 72 Question?
Old Jan 15, 2010 | 06:44 AM
MNS's Avatar
MNS
Code 72 Question?
1995 F-150 4X4 5.8. New plugs, wires, rotor, tps and map sensors. Cleaned egr valve and tested evp sensor. Engine light keeps coming on. Advice appreciated. Thanks
Old Jan 15, 2010 | 07:32 AM
Lazy K's Avatar
Lazy K
Your truck should have three digit codes.
Old Jan 15, 2010 | 07:44 AM
MNS's Avatar
MNS
I went to Auto Zone and they gave me the code KOEO. I checked and at the beginning of the scan the #111 came up. After a delay Code 72 KOEO. I've disconnected the battery, but the codes keep coming back. Thanks
Old Jan 15, 2010 | 11:54 AM
Lazy K's Avatar
Lazy K
Strange. Go fordfuelinjection.com and from the list on the right, click on "self test". You can then follow the instructions and pull the codes yourself. Any codes you get should be 3 digit. There is also a list there of what each code refers to.
Maybe some of the experts will give an opinion soon.
If you do get the codes post back here and there plenty of guys to help you.
Old Jan 15, 2010 | 03:34 PM
MNS's Avatar
MNS
I did the KOER test and 172 code came up. Does this truck have a MAF sensor? I believe that 3 digit codes started for 96 and 95 diesels(not sure).Thanks
Old Jan 16, 2010 | 07:02 AM
Lazy K's Avatar
Lazy K
The three digit codes came in about `91. MAF I think came in in `96.
172 is oxygen sensor not switching and system is or was running lean.
My thoughts would be to replace the sensor, clear the code and see if that fixes it.
It would nice to get an opinion from Conanski though.
Pyancey
Jan 16, 2013 09:08 PM
digdug442
1997 - 2003 F150
Sep 7, 2009 11:08 AM
Workin4ALivin
Jun 28, 2009 03:41 PM
tadssman
1983 - 2012 Ranger & B-Series
Jan 11, 2007 11:19 AM
ford4x4offrd
Jul 2, 2001 06:20 PM
