Ranger O2 sensor
Old Jan 10, 2007 | 03:46 PM
tadssman's Avatar
tadssman
Ranger O2 sensor
Have never changed a O2 sensor before. I need to know where the before Cat sensor is located. 2000 Ranger 4.0
Old Jan 10, 2007 | 03:48 PM
rbengl's Avatar
rbengl
My 1996 has two. One in each header pipe but before they come together to go into the cat. So you need to know which one to change. Left or right?
Old Jan 10, 2007 | 03:52 PM
tadssman's Avatar
tadssman
Right side
Old Jan 10, 2007 | 04:12 PM
rbengl's Avatar
rbengl
Maybe someone else will jump in and verify this, but I think that is the passenger side. So it'll be in the exhaust header pipe coming down from the passenger side of the engine. Not too hard to change, you can get a replacement at most auto parts stores. Just make sure the new one either has the compound on the threads or you get that as well. (All the one's I've seen come with it already on the threads). Then it's one electrical connection and unscrew it, screw in the new one and reconnect.
And if you don't get a verification here which side, the auto parts store should be able to tell you also.
Old Jan 10, 2007 | 04:19 PM
pgw85706's Avatar
pgw85706
Check the Tech Info page. The members of this forum and done an excellent job to capture a lot of their knowledge into this area.
http://rockledge.home.comcast.net/RangerPictureGallery/HO2SLocation.html
Old Jan 11, 2007 | 06:19 AM
grease monkey's Avatar
grease monkey
You will need a special socket for the sensor to remove it since the wires are on it. I bought one at Napa for $8 or so. Also a little extra motivation might help like a breaker bar because more than likely the old one is rusted on there.
Old Jan 11, 2007 | 11:19 AM
Bart99GT's Avatar
Bart99GT
A box end wrench works much better than those sockets with a cutaway, unless you get an expensive one from Snap-On, Mac, etc.. The parts store ones just flex too much and end up slipping if the sensor is really stuck. Though most replacement O2 sensors have a little anti-seize on them, I always add a little more just to make sure the next one doesn't get stuck.
Also, I wouldn't fool with the after-cat sensor unless the computer is throwing a code about them. They only monitor converter efficiency.
radramrod2
Aug 15, 2015 08:30 AM
Frodo79
13
May 20, 2012 04:04 PM
Eaglefixer
20
Sep 13, 2010 06:52 PM
Ranger GT2
Nov 22, 2009 10:04 PM
stupid red ranger
Jan 28, 2004 11:21 PM
