what trans is this
Old Jan 12, 2010 | 08:54 PM
JHAM's Avatar
JHAM
what trans is this
my 5 speed trans went out and i have an automatic that i am going to put in my 96 4x4 f150. i was told by my friend that i got the trans from that he thought it was a c6, but i dont know what to look for to tell for sure. any help would be appreciated. i know that a c6 has 17 bolts on the trans pan, but i dont know if any other transmissions are the same. thanks for any help.
Old Jan 12, 2010 | 11:49 PM
85e150's Avatar
85e150
Info:
Ford Transmission Spotter's Guide .: Articles
Your C6, is it for a 4x4? Does the bell pattern match your engine?
You should expect to have to fiddle with the cross member, and move the TC and re-do both DS if the length is different.
If it is not a 4x4 model and you have a married TC, forget it, changing the tailshaft requires a complete teardown.
Is this what you're trying to figure out?
Old Jan 13, 2010 | 04:31 AM
Lazy K's Avatar
Lazy K
What he says and the C6 is the only one with 17 pan bolts.
Old Jan 13, 2010 | 09:14 PM
JHAM's Avatar
JHAM
yeah i know i might have to have the driveshafts lenghtened/shortend, and i also know about the crossmember, the trans is a 4x4 trans with the transfer case on it. also, is there a number on it i can check to find out what vehicle it came in so i know what filter to get for it? all the parts stores want to know what year vehicle it came out of, and i have no idea. im not sure what year trucks came with a c6, or if there were different filters for any of the transmissions
Old Jan 13, 2010 | 11:17 PM
Ford_Six's Avatar
Ford_Six
The only thing that might give you that info would be the tag on the servo cover. If that tag is missing, there's just a few different versions- 4x4 used a deeper pan, about 2" deep altogether, while car and 2wd truck used a pan about 1" deep from what I remember. I know the shift arms for car and truck are different, I think car points up and truck points down.
