6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Reality Check
Old Jan 14, 2010 | 08:55 PM
kcb37's Avatar
kcb37
I will also add cause I am slow, apparently.
Any diesel will cost more to maintain. Not sure how much a 6.0 or 6.4 takes for oil I know my 6.6 Dmax takes 10 qt for the engine. Granted this is more then a gas, but at the same time you have to buy diesel oil. If you get dino it's not bad, synthetic can be costly. Do some searching sure their is alot of info here. If not PM me and I will send you a link. Either way a 3/4 or 1 ton in general cost more, brakes, steering, ect...
However I will add I really don't care what I pull, truck can handle it, Ford, Chevy, Dodge shouldn't matter really. However the only thing I would say is if your legal or not as far as the trailer towing capacity and GVWR of the truck. Other then that, if you can't pull it something is wrong with your truck. That goes for all of the big 3.
Old Jan 14, 2010 | 08:58 PM
koboss1's Avatar
koboss1
wrong board my friend!!!
have fun with ur chevy
Old Jan 14, 2010 | 09:08 PM
kcb37's Avatar
kcb37
Maybe you think so, might want to read all that again. I realize that I own 3 Chevy's at the moment. However if you read what I said it applies to anything really. Just using mine as an example.
In that spirit, I will also add this. Don't know how much of a deal it is with Ford's, but I do know alot of Chevy guys will put either 2 cycle (TC-W3 Marine grade) to their fuel, also Staydine, Diesel Kleen, Power Service, I use Opti- Lube XPD. This is for lubrication due to ULSD not having any. Do some searching you should find something. Point of that being. Take care of your truck it will last longer.
I use Opti-Lube because ULSD dose not have any (well a very little) lubrication, also has cleaner in it too. I will aso add that I bought mine at ( I think it was 89k, now have 107k runs great for a truck with known injector problems)
87f150mudder
Jul 26, 2013 11:22 AM
Chris Braun
Sep 15, 2012 06:37 AM
Iversen-fords
26
Apr 10, 2011 10:20 PM
elkhuntr
Oct 27, 2004 06:24 AM
wackypacky
All Things Towing
Jul 7, 2004 09:55 PM
