Cammed Dents
Old Jan 12, 2010 | 06:45 PM
Kirbys73F100's Avatar
Kirbys73F100
Cammed Dents
So I finally fell victim to making a Youtube exhaust video so here it is... My '73 F100 Ranger. I have Quick Time Performance electric cutouts on it. Opened up at 25 seconds. Let's see some more lopin' dents.
1973 F100 Video 1
1973 F100 Video 2
Old Jan 12, 2010 | 07:09 PM
79FordBlake's Avatar
79FordBlake
Nice sounding and looking truck. I don't have a vid but I have a sound clip of my 79 F150 but don't know how to post just a sound clip.
Old Jan 12, 2010 | 07:34 PM
Kirbys73F100
Thanks! If you have a video editor you could put up a still picture of your truck and play the recording in the background.
Old Jan 12, 2010 | 08:56 PM
Drac's Avatar
Drac
Save the old ones
What Cam did you put in your 351W? Stock Heads?
Old Jan 12, 2010 | 09:07 PM
Kirbys73F100
Comp Cams .500 lift and stock heads minus dual coil valve springs. Truck also has MSD distributor and coil, dual chain timing set, edelbrock performer single plane intake and carb 600 cfm.
I'm pretty sure this is the cam i bought.
Old Jan 12, 2010 | 09:41 PM
79FordBlake
Did you use your stock converter? I have a 278 crane cam in mine. Its a 302, 30 over, double roller chain, timing gears set at zero, Edelbrock Performer Intake, Edelbrock 600 carb. I am using the stock converter. I think I need to get one with atleast a little bit of stall in it. Cam I have don't come alive till about 2,200rpm.
Old Jan 12, 2010 | 09:54 PM
Kirbys73F100
I have a stock converter. Lemme guess.. It'll barely do a burnout in the dry but it hauls ***** after you get it movin'? ... I hate to admit this but I have the same problem.. My truck doesn't make power until around 2,000 either. I too have debated running a stall converter but it really doesn't solve the issue and its harder on the rest of the drivetrain. I'd hate to tear up my Detroit locker just so my truck will launch harder. This issue is the reason I took the time to tear apart the front of my engine and advance the timing gear but to no avail so don't waste your time. It's also the reason I went with the 4.11's instead of 3.73's. I even bought the MSD dizzy and coil which I don't regret because these only improve efficiency and power, especially when I finally buy heads for it. I've talked to several knowledgeable people about this and we've come to a common idea. The stock smogger heads on the '78 windsor just suck. I've also thought about buying an offroad cam to provide for more low end power but I just can't bring myself to take out my buggity cam and run less lift.
Old Jan 12, 2010 | 10:00 PM
79FordBlake
Absolutely hit the nail on the head!!! lol. I have 3.00 gears. I raced a 5.4 triton one day and it was stock. Off the line he left me probably by 3-4 cars lenths. Then on the long stretch I started catching up and passed him, lol. With the shift kit it has if you floor it off the line won't shift to 2nd till 65mph. I just set and laugh when people think they beat me, then I catch up and pass them, lol.
Old Jan 12, 2010 | 10:02 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
YouTube - Ford Truck Dual Quad
YouTube - Ford 428 Exhaust
YouTube - Ford Dual Quad Close-up
Josh
Old Jan 12, 2010 | 10:10 PM
Kirbys73F100
What year engine is in the truck? Stock heads?
Glad to hear I'm not the only one out here chasing low end torque with my small block... I was actually kinda okay with it until I landed a '65 F100 with a 429 in it and shortly after bought a '79 F250 4x4 with a '71 460 in it. These trucks HAUL ***! Hence my new favorite phrase, "There's no replacement for displacement" These two stock big blocks absolutely roast my "mildly built" 351, at least on the bottom end. I haven't lined these trucks up to see how the big blocks perform against the Windsor at top end though. It could surprise me but I don't know. I DO know that my '79 spins 44's on the dry street with stock 4.10's just as fast as it spun 33's. The '65... its just stupid torquey. Anyways, moral of the story is, I'm taking the 429 out of the '65 and putting it in my '73 this summer! The '65 doesn't have power brakes or power steering so the big block will be better suited in my Ranger.
Old Jan 12, 2010 | 10:14 PM
Kirbys73F100
Josh, awesome truck!
Old Jan 12, 2010 | 11:18 PM
OrangeJuice's Avatar
OrangeJuice
You both have nice trucks...
OJ
Drac's Avatar
Drac
Save the old ones
Your truck sounds great!!
Hope mine sounds as good
I was curious as I'm in the process of putting a 351W in my 79.
I have not fired my motor yet due to some snags on the exhaust.
I put a Comp 4x4 cams 35-239-3
.493 & .512 lift, 262/270 Duration
Edelbrock Air Gap Performer
625cfm Speed Demon
Trick Flow Heads
It just kills me i haven't fired it yet. your video might just get me off my but and get it going this month
Thanks
Old Jan 13, 2010 | 09:56 AM
Kirbys73F100
Looks to me like its gonna sound kickass! You've done something I didn't have the money to do.. buy trick flows. So it's gonna run as good as it sounds. I can recommend buying those Quick Time Performance electric cutouts or just bolt up cutouts because it really makes the truck turn into a growling beast when it idles. It's a nice little weapon to have when a 5.0 mustang pulls up next to you at a stop light. I have xcellerator mufflers and i love em. They have several different sounds throughout the rpm range unlike slowmasters... What are you runnin? Anyways, GET IT DONE! So we can hear it.
Old Jan 13, 2010 | 10:02 AM
Kirbys73F100
Just typed in that part number in Summit's site. That must be a new cam, maybe that will help 79FordBlake and I. I hadn't seen a high lift cam with such a low rpm power range.. I'm very interested to see how your truck performs on the bottom end. I'm tempted to just order that cam right now actually!
