4x4 conversion finished!
Old Jan 13, 2010 | 12:33 PM
Fullcrew7.3's Avatar
Fullcrew7.3
Originally Posted by Neal 97 250
You are more than welcome. What do you want to do?
?????Sorry, I missed something. Do???? To the truck? with the truck?
Old Jan 13, 2010 | 12:59 PM
79f-250custom's Avatar
79f-250custom
there is no truck cooler looking than an OBS 4 door dually IMO.
so what was the hardest thing to do on this truck.
was everything bolt on? or did you have to drill holes for the leafs.
more details plx.
Mitch
Old Jan 13, 2010 | 01:00 PM
95_Dually's Avatar
95_Dually
I want to show up with a two wheel drive dually with a 4 wheel drive srw on a trailer and leave with a 4 wheel drive dually and a 2 wheel drive srw on a trailer. Unless you want whats left over. Then I would go home with an empty trailer.
How does that sound?
Old Jan 13, 2010 | 01:11 PM
Fullcrew7.3
Ha Ha, sorry, I forgot about 95 dually's post.
Old Jan 13, 2010 | 01:13 PM
Fullcrew7.3
Had to drill 38 holes for the RSK in front and 6 for the shackle flip in the rear. It was the coil spring to leaf spring conversion that made for the most work.
Old Jan 13, 2010 | 01:18 PM
Fullcrew7.3
Also, I had to get the front bumper mount wleded in from the donor truck Check out the pics in my gallery in the RSK install album and you figure that part out pretty quick.
Old Jan 13, 2010 | 01:47 PM
Neal 97 250's Avatar
Neal 97 250
Man that's alot of holes. Got any frame left? LOL
I hear the Ford frames are harder to drill thru than the other two big names.
I drilled my frame once wasn't as hard as i expected but no walk in the park.
That bumper mount must be in 4X4's only. Mine already has it. I have seen people completely box in the frame in front to stiffen it up.
Why so many holes in front. Front spring bracket, Rear spring bracket, maybe shock bracket.
Oh well that is a nice install and I admire you did it in the weather nonetheless. Use much antifreeze/booze? LOL
Old Jan 13, 2010 | 04:37 PM
Fullcrew7.3
Front and back mounts. Shock mount, stabilizer bar bracket, Sorry, recount. 38 including the rears. The drilling wasn't too bad. All 1/2" holes. Yeah, the longer bumper mount/cab mount is only on the 4x4's. 2wd's only have a small bumper mount bracket.
Nope, no 'antifreeze'!
Old Jan 13, 2010 | 05:06 PM
95_Dually's Avatar
95_Dually
38 holes is still a lot of holes. 1 bit did the job?
Old Jan 13, 2010 | 07:56 PM
Fullcrew7.3
Naw, I had a spare and good thing too. I broke the first one. If I'd have thought to use a cutting oil for the first half of the holes, it might have made all of 'em. Duh!
Just pulled off the front driveshaft and took her for another spin. All the noise (at higher speeds 55-60) is gone. Dropping the front shaft off to get balanced tomorrow. That should fix it.
Old Jan 13, 2010 | 07:59 PM
95_Dually's Avatar
95_Dually
Awesome. You should be very proud of what you have created.
Old Jan 13, 2010 | 08:14 PM
Fullcrew7.3
Thank you very much. If there's anything that I can do to assist anyone in doing this to their trucks, let me know. Any additional pics, I'll try to accommodate.
Old Jan 13, 2010 | 09:44 PM
  #28
joe_13894's Avatar
joe_13894
I'm just interested in everything that must be done up front to get that D60 in. I don't want to raise it any farther than I have to. I carry a large truck camper and raised isn't a good thing for highway driving. I have debated the idea of putting a D50 TTB up there and keeping the coil springs... I'm just not sure that's a good idea from the perspective of how much weight transfer can occur with the camper on.
As far as the transfer case: I got a divorced case off of a '76 F250. I'm going to hang that behind the transmission with a short intermediate drive line so I don't have to mess with converting an automatic transmission over.
Old Jan 13, 2010 | 10:29 PM
  #29
Diesel_Dirk's Avatar
Diesel_Dirk
looking good.
Old Jan 14, 2010 | 06:18 AM
  #30
Neal 97 250
The D50 TTB use leaf springs from the factory. Not sure I would want it on coils.
