Sponsored by: Auxito
P0171 after spark plug change
Old Jan 12, 2010 | 04:04 PM
jennkent5454's Avatar
jennkent5454
2003 F150 5.4L FX4
changed the spark plugs today and tore the pcv rubber connector on the tube, I drove it with the tube removed to the auto parts store and got a piece of hose to make the fitting. I put the tube back on at the parts store and noticed the CEL was on, read the codes when I got home and got the P0171. since I replaced the tube will the CEL turn off after awhile?
Old Jan 12, 2010 | 08:07 PM
fordtech08's Avatar
fordtech08
why did you not clear the code when you checked it, it might never tried it
Old Jan 12, 2010 | 08:27 PM
jennkent5454
I just cleared it, so it should be good?
Old Jan 12, 2010 | 08:29 PM
fordtech08's Avatar
fordtech08
as long as there isn't another problem
Old Jan 12, 2010 | 08:31 PM
jennkent5454
cool, thanks!
I guess I was wanting the CEL to go off on its own as soon as the problem was repaired..
Old Jan 12, 2010 | 08:34 PM
fordtech08's Avatar
fordtech08
only works for abs problems
rustybuttrusty
3.8 & 4.2L V6
Feb 2, 2016 03:39 PM
dalberti
1997 - 2003 F150
Mar 31, 2015 01:49 PM
diehardgator1
2004 - 2008 F150
Feb 16, 2010 11:00 PM
brian_06328
Oct 1, 2006 11:59 PM
