HPOP
Old Jan 12, 2010 | 10:46 AM
1950gmcelc's Avatar
1950gmcelc
HPOP
Will a 96 hpop work on my 95? I found a reman
F6TZ9A543ARM 96-97 FORD SUPERDUTY INJECTION PUMP for $50 but before I buy it i wanna make sure it will fit. Also will I get anymore power with this pump. Thanks as always for the help.
Old Jan 12, 2010 | 10:54 AM
strokin'_tatsch's Avatar
strokin'_tatsch
Nope, you can only use a '95 HPOP. if you use a '96-up HPOP u will have bleed back issues and if you use a '96-up gasket it will leak. only use a '95 HPOP and gasket. haha. you can call Joey at terminator and get a modded 17* w/ a '95 housing that will allow you to run more power(injectors and custom chip) if your looking for an upgrade pump or you can swap to a '96-up front cover or run a search for the '95 front cover mod to fix the bleed back issue we have with the '96-up pumps. only the SD pumps are upgrades for us though(late99-03)
Dav67Kel
Mar 1, 2015 05:17 PM
lotech
May 27, 2014 09:29 AM
DSMMH
May 1, 2014 07:50 AM
Jesser02EX
Mar 20, 2014 11:20 PM
coreyb
Mar 31, 2005 01:00 PM
