Gaskets on HPOP
Old May 26, 2014 | 10:06 AM
lotech's Avatar
lotech
Gaskets on HPOP
are there two? I know the cover lid needs one, but is there a bottom one as well? HPOP part # (P1) 1831022C96. This is E99
Old May 26, 2014 | 04:19 PM
senix's Avatar
senix
What year and motor for your truck?
Old May 26, 2014 | 04:23 PM
lotech's Avatar
lotech
Early 99 7.3 diesel
Old May 26, 2014 | 04:43 PM
senix's Avatar
senix
I moved this to the 7.3 forum. I think you will get the better responses there.
Old May 26, 2014 | 04:49 PM
lotech's Avatar
lotech
I was not to clear on this, the gaskets are on the resevoir. The lid has one and I asking if there is another in the bottom?
I have a Chiltons, tells me everything except what I need.
Old May 26, 2014 | 04:50 PM
whitetmw's Avatar
whitetmw
Single Gasket - RTV on the front cover on the early 99's.
Old May 26, 2014 | 06:12 PM
FiznUKa's Avatar
FiznUKa
I just r&r'ed mine on sat there are two o-rings one on the top cover and one for the base. Before you remove it drain the oil with some sort of pump like a hand cleaner pump or what I used was a pump for filling my boats drive oil. Expect about a quart or so other than that it went fairly smooth. I ordered mine through riff raff just make sure you get it for your model one has a screen and one does not.
Old May 27, 2014 | 09:29 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Here are links to the ones you will need on your Early 99
HPOP Reservoir Gasket 96-99.5 - Riffraff Diesel Performance
HPOP Reservoir Top Cover O-ring - Riffraff Diesel Performance
If you have any questions just let us know.
MDSuperDuty
Jul 15, 2017 11:20 PM
ramhunter5877
Jun 20, 2014 07:11 AM
Davepomrenke
May 28, 2013 05:02 PM
brands
Dec 11, 2010 02:43 PM
bigfordmatt
Oct 21, 2009 07:47 PM
